Old 13th December 2009, 04:27 PM   #21
SY's Avatar
For you again, i am not a developer to answer questions about different stage technics.
Then why did you open a thread for circuitry discussions? Part of discussion is understanding reasons and rationale.
If there's a sucker born every minute, where do the rest of them come from?
Old 13th December 2009, 07:22 PM   #22
oshifis is offline oshifis  Hungary
Tube-I-zator, Lampizator... Hm, should I establish an audio enterprise named Valve-I-zator?
Old 13th December 2009, 08:51 PM   #23
kevinkr's Avatar
I think the SRPP has become something of a tube audio design fashion statement, and possibly an irrational one at that.. I used them a lot in some of my older designs, and perhaps (definitely) a bit too widely. To my chagrin I found some real practical downsides to its use including excessively high output impedances with low transconductance high mu triodes like the 12AX7A/ECC83. (Much worse incidentally that a straight CC stage driving a CF in this case.)
About 11 yrs ago I designed a phono stage that used one in the output stage and lost the possibility of a very lucrative distribution agreement because it could not effectively drive the capacitance of the most popular interconnects of the day. It bombed in a critical 3rd party system evaluation for that reason, despite my verbal warning about its inability to drive very capacitive cables.
There are other shortcomings including linearity and noise where it is generally inferior to the mu follower, and a CCS (or resistively) loaded common cathode stage.
It is quite good at driving the specific load impedance for which it was designed and for delivering some appreciable amount of power into a load. It is not a great choice where the primary goal is voltage gain, and the wrong choice in tube type will result in a stage that can't drive even reasonable loads. (Usually the result of needing voltage gain)
I still admit to liking the way the 6SN7 sounds in SRPP configuration, and use it that way in one of my old line stages, I also use it to drive the output stage in my SE amplifier where it works pretty hard, and gives a good account of itself. Certain tubes like the 6021 IMHO sound dreadful and produce bad measurements when used in SRPP. I haven't designed anything using this topology since about 1999..
How about a 5842 with a CCS load, and LED bias, output impedance will be <2K, (or you could configure as a mu-follower using a DN2540 mosfet) gain is high enough that a very small I/V resistor could be used for good dac linearity, and it is extremely low noise.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 13th December 2009, 08:53 PM   #24
SY's Avatar
Nope, makes way too much sense.
Old 13th December 2009, 09:42 PM   #25
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Me too would think the simpler/se stage would be better...but then again, John Broskie/Tubecad gets away using SRPP in a RIAA...
Arne K
Ars longa, vita brevis
Old 13th December 2009, 09:54 PM   #26
kevinkr's Avatar
Arne K
I made that mistake once..
Old 13th December 2009, 09:54 PM   #27
diyAudio Moderator Emeritus
Bas Horneman's Avatar
And then maybe even add the Salas Simplistic Mosfet HV Shunt Regs? That would be a cool pcb.
Old 13th December 2009, 09:57 PM   #28
Good suggestion - a 7119 with a 1:1 transformer is my chosen solution...for now at least
FWIW: Our SRPP experiences are very similar, Kevin.
Jim
Old 13th December 2009, 10:02 PM   #29
Is the transformer before or after the 7119?
Old 13th December 2009, 11:44 PM   #30
After.
Jim
Tube-I-zator Professional PCB dvb-projekt Group Buys 816 12th May 2013 03:01 PM
Built the DDDAC MKII USB audio card, modified it to feed SRPP tube amp line stage wa2ise Tubes / Valves 0 8th June 2008 03:21 AM
srpp input stage nhuwar Tubes / Valves 11 31st July 2007 10:03 PM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 05:21 PM
CF and SRPP in one circuit . . rick57 Tubes / Valves 5 21st May 2006 11:58 PM
Copyright ©1999-2013 diyAudio
