Old 26th May 2003, 10:23 AM   #1
Default Suitability of ecl84 tubes for audio
Hello everyone,
Just bumped into a bunch of ecl84/6dx8 tubes, logicly they should be O.K. for audio use. Anyone had a chance to play with these or has an opinion plaes do.
Thanks.
Glass_painter.
Old 26th May 2003, 11:52 AM   #2
diyAudio Senior Member
fdegrove's Avatar
Default ECL84.
Those were often used in TV sets, you could use it for audio much the same way as the ECL82.
Frank
Old 26th May 2003, 02:33 PM   #3
Tom Bavis's Avatar
The pentode has an anode rating of 4W, so it isn't as beefy as many of the ECL.. series tubes. But it would make a nice constant current sorce for the triode.
Old 26th May 2003, 05:54 PM   #4
Default ecl84
Thanks for all the info.
I listen mostly to headphones so I am not to worried about the wattege of the tube, however I am very pickey about the sound, what would you expect the tube to sound like compare lets say to ecl82 or ecl86 knowing that this tube was developed for video applications.
Thanks.
Glass_painter
Old 26th May 2003, 07:16 PM   #5
fdegrove's Avatar
Default ECL84
If you know that the ECL86 is 1/2 ECC83 +one EL84 in a single envelope and you know what those can sound like than that's one out of three eliminated.
One or two other members have developed and built an amp around the ECL82 recently and seemed absolutely pleased with the results.
You can do a search locally for 6BM8/ECL82
I remember this valve to be popular in Holland back in the fifties so somewhere there must have been audio amps using this valve.
The fact that its' primary design goals were targeted at video/TV applications wouldn't stop me from trying it out.
Frank
Old 27th May 2003, 05:28 PM   #6
frugal-phile(tm)
planet10's Avatar
Default Re: ECL84
Which i have seen described as an ECC81 + EL84.
I'll be interested in your 6DX8 results -- i think i have some of those in my collection.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th May 2003, 06:31 PM   #7
fdegrove's Avatar
If only that were to be true...
I haven't figured out what it is but the penthode can only dissipate 5W according to my GE databook wheras the mighty
little EL84 will blush at 12W.
The triode part of the 6BM8 as a u of 70 so that puts it close to the 12AT7 family.
Cheers,...I hate to bring bad news...
Frank
Old 27th May 2003, 06:37 PM   #8
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Just for the record
The triode section was designed for use as a switch for "keyed AGC".
It spent 60uS out of 64uS with -150v on it's anode, only turning "on" to sample the video signal level during the sync period.
The pentode section was a reasonble amp up to 5.5MHz (with a little peaking).
Old 27th May 2003, 08:09 PM   #9
frugal-phile(tm)
planet10's Avatar
but the penthode can only dissipate 5W ... little EL84 will blush at 12W.
I knew that the ECL82 didn't have as much grunt as an EL84, (ie potential 8 w PP vrs 20 in EL84) so was careful in attributing it to someone else
It did fish out the info i was lookin for... thanx Frank.
dave
Old 28th May 2003, 01:50 AM   #10
fdegrove's Avatar
Default MOST ECLS...
You're welcome...
Mind you, most of this ECL range can be put to good use in mu-follower preamp service.
The ECL86 is my dream candidate for a mini bedroom amp though...
I'm still surprised David Manley didn't consider it for his love Tiny Triode amp.
So, don't junk your ECLs just yet...
Frank
Suitability of mosfets!! sandyhooker Pass Labs 5 15th February 2008 02:37 AM
Suitability of transmitter tubes for musical amplifiers Svetlana Tubes / Valves 20 31st August 2006 03:18 AM
voltage regulator using ECL84 + OB2 ErikdeBest Tubes / Valves 19 5th November 2005 11:19 AM
Copyright ©1999-2013 diyAudio
