| diyAudio Sponsor | ||
#41 |
Hi phildas
For my PCL84 amp I used Hammond 125ESE OTs. 10 K - 8 ohm connected. They are not very beautiful but they sound very well. They cost 65 $ each. See the characteristics at Hammond Mfg. - Universal - Single Ended - Tube Output Transformers - (125 Series) |
#42 |
thanks for the reply!
Any details as to how something like this can be custom wound? Thanks! |
#43 |
With great care and some trepidation.
Reading this thread will give you some idea. It takes specialized talent and knowlege to wind a transformer safely and properly. Choosing an output transformer |
#44 |
the pentode section of the PCL84 / ECL84 is nice linear in triode mode
The amount of humans is increasing, but the amount of available intelligence remains a constant. |
#45 |
Hi phildas
Some time ago I have been also interested in transformers' design and winding and I did some searching in the Web, but it is too difficult for me. Here are some links: Transformers Part 1 - Beginners' Guide to Electronics Building an output transdformer for a tube amp Output transformer design and winding Good luck |
| Suitability of mosfets!! | sandyhooker | Pass Labs | 5 | 15th February 2008 02:37 AM |
| Suitability of transmitter tubes for musical amplifiers | Svetlana | Tubes / Valves | 20 | 31st August 2006 03:18 AM |
| voltage regulator using ECL84 + OB2 | ErikdeBest | Tubes / Valves | 19 | 5th November 2005 11:19 AM |
| Page generated in 0.08574 seconds (75.63% PHP - 24.37% MySQL) with 11 queries |
