diyAudio Sponsor
Old 8th December 2009, 05:37 AM   #1
Default Newbie questions - RH84 mods
I find myself in a strange position. I've been around this forum for years, I have a website with information on valve tech and I've spent most of my life around electronics. Despite this, I've actually built very little.
I've spent too much of the last 10 years living in other countries out of boxes to actually have a workbench set up, but I've finally got there in the last couple of months. I inherited quite a lot of equipment from my father (an EE) a few years ago, so I'm fairly well resourced, but I'm making newbie mistakes.
So I feel a little awkward, try not to laugh.
What I have is an RH84 amp breadboarded on my workbench. It works fine and sounds rather nice. Produces about 1.9W at onset of clipping, for 1.2VRMS in. Powersupply is an old bench unit (two outputs plus bias and heater supplies, etc), so I have a lot of flexibility.
What I noticed when poking around with an oscilloscope is that the input stage is the first to clip. So, I thought, why not use the powersupply and power the two sections separately. That way I can tweak the input stage without mucking with the output stage. So I've discarded the 10k resistor, 10uF cap and 22k resistor and I'm putting 160V (measured in circuit previously) directly on the plate of the 12AT7.
I now get no signal out of the 12AT7 and I don't understand why. I'm measuring signal at the junction of the 220R resistor and 0.22uF cap.
Anyone able to illuminate me?
In the end I will try and redesign the front end to use 6EJ7/EF184 as I have heaps of them and only two 12AT7, but there is a bit of learning to do to get to that point.
Old 8th December 2009, 05:52 AM   #2
aardvarkash10's Avatar
lol ! thats the sort of thing I'd do! You just removed the resistor that provides the voltage signal...
Put the 22k resistor back in, and I think you will be good to go - at least you'll have a signal being developed.
Cheers
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 8th December 2009, 05:57 AM   #3
hope that didn't sound too rude. Look at the circuit - the 22k resistor is one half of a voltage divider - the 12AT7 is the other. As the AT7 changes resistance, the voltage at the junction of the AT7 and the 22k resistor changes - this is your output voltage. Without the 22k, you get no voltage change, hence no signal.
Hope that helps a little more than my sophomoric schadenfreude.
Old 8th December 2009, 06:02 AM   #4
Aaah. That makes sense. So the 10k resistor is a voltage dropper, the 10uF cap is additional filtering and the 22k resistor is as you describe. Am I correct?
Out of curiosity, how would the value of 22k be arrived at?
Old 8th December 2009, 06:40 AM   #5
In essence, yes!
the 22k is set to provide the voltage signal you need and deduced by looking at the anode curves for the tube. Good description here. Yes its long, but you REALLY need to understand this shizzle before you dive in any further. Otherwise you are painting by numbers... Enjoy!
Old 8th December 2009, 07:45 AM   #6
revintage's Avatar
It is not even close be optimal using a triode as driver in a Schaded/plate-grid feedbacked amp. The only relevant mod is to use a pentode at higher current as driver as your idea is. Parallelling the AT7 makes things worse as Ri gets even lower.
Brgds
Lars
Old 8th December 2009, 09:24 AM   #7
pauldune's Avatar
I thought the ef184 he proposed is a pentode? And i dont see were he says that he wants to parallel the at7 halves?
Could he use a srpp first stage? Then he could use both halves of the at7, and at the same time increase max swing.
Or isnt that usable with a schaded/plate grid fb amp?
Old 8th December 2009, 03:37 PM   #8
revintage's Avatar
As I said:
SRPP (The SRPP with its load-critical PP-function isnīt generally seen so particulary good in any placeIf wanting to go that route a high Gm pentode or MOSFET on top will be the better choice) is even worse as output impedance should be as high as possible to make the driver being a current amp.
Did a quick check at the curves for EF184 and a starting point could maybe be Ua 150V, Us 230V and Ik 15mA. Then itīs up to distortion-cancellation to do the rest.
Brgds
Lars
Old 8th December 2009, 06:22 PM   #9
pointy is offline pointy  United Kingdom
pointy's Avatar
10k is the CCS resistor (it helps to control the current to the ecc81)
10uf is to drain off any AC
22k is the anode-plate resistor
ecc81's will clip if pushed, if you used a ecc83 this would stop but you would need to keep the in-put under 500ma -ish
and change all the resistors via a datasheet
and reset the control grid of the el84 may-be
Old 9th December 2009, 08:09 AM   #10
revintage's Avatar
Hey Pointy,
This make no sense. The plate-grid feedback makes the EL84 current input so the wimpy ECC83 won´t do at all. We need at last 5mA but preferably more ideally using a highGm pentode-driver as I mentioned before. The reason for is that the effictive Zin of the EL84 is below 2kohm. So using a triode will give substantial distortion.
Reading RDH4 that has a part(see below) dealing with this subject is a good starting point. The last sentence is essential, still a high-mu triode mentioned needs to be biased with maybe 10mA current. Still it will surely distort. Pentodes on the other side, needs a hard load to work properly.
A E280F or D3a would be great. The nice pentode section of the 6F12P would make the lowbudget alternative. And the thevoice´s EF184 will surely be a good start. Preferably it should also be fed by a gyrator/AC-CCS.
Brgds
Lars
Denon 2900 mods. Newbie needs help. ggante Digital Source 0 14th May 2009 03:21 AM
RH84 questions kacernator Tubes / Valves 13 22nd April 2009 06:14 AM
newbie non solder mods? futuremod Analog Line Level 0 24th January 2009 06:20 PM
Philips CD620 mods, newbie here... bleachershane Digital Source 1 2nd December 2008 04:10 AM
CD player mods-newbie quan Digital Source 13 22nd April 2007 08:48 AM
Page generated in 0.10588 seconds (84.87% PHP - 15.13% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
