Old 25th May 2003, 11:36 PM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default How much capacitance for tube rectified PSUs?
Here's what my idea is so far. A choke input PSU using a 240VAC transformer rectified using a 5AR4, fed into a 10H choke, then 300uF, then another 10H choke followed by another 300uF. Is this too much capacitance for the tube rectifier to take? First amp using tube rectifiers... If so, what values should I use? I've already got the two 10H chokes, so those values are set.
Old 26th May 2003, 12:15 AM   #2
diyAudio Senior Member
fdegrove's Avatar
Default NO PROB.
The GZ34/5AR4 only cares about the capicitance it sees before the choke.
Since you intend to use a LCL filter it shouldn't matter.
What can occur though is that the chokes go into full saturation/conduction but that would depend on the load...so no further comment so far.
Don't worry, you'll be fine.
Frank
Old 26th May 2003, 12:37 AM   #3
Brett's Avatar
Model it in PSUD to make sure it's not going to saturate the choke or exceed either the peak or average current of the GZ34.
Old 26th May 2003, 01:13 AM   #4
JoeBob's Avatar
Well, thanks. I knew in a CLC circuit the second C could be larger than the first, but I knew not about choke input circuits. I feel better about it, since I already had the six 100uF caps that config qould be
learning tube rectified psu milen007 Tubes / Valves 26 21st September 2008 12:28 PM
Looking for a PCB / kit for a bipolar tube rectified PSU luvdunhill Tubes / Valves 10 16th August 2007 01:23 PM
PSU question? Going tube rectified sbelyo Tubes / Valves 47 2nd June 2006 09:27 PM
tube rectified preamp schematic sv62 Tubes / Valves 14 30th June 2004 10:16 AM
Page generated in 0.54961 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
