| diyAudio Sponsor | ||
After much frustration with a 6H6Π LTP design intended for SE to balanced conversion, this is my new line stage plan. Please openly comment/suggest!
'in acts and works bigger than a great wale's tail' |
#2 |
Mind you, them 6j5's, they don't go cheap eh? Not to mention the god**mn Lundahls, but will it play music?
#3 |
did you calculate gain ?
anyway - I like big xconductance tube in that position ..... WOT preamp and battery charger
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#4 |
x19 from 6j5 = 25.5dB
-2.5dB from shunt volume control -13dB from tranny =9.6dB, if I am correct.
#5 | |
#6 |
HI,
I built a transformer coupled pre that was originally going to use 6j5Gs but sticker shock got me to wire it for ˝ 6sn7. I still used two tubes but set it up so that the two channels used opposite triode sections. That actually worked out pretty well as I was able to get some good tube matches by swapping channels. |
#7 |
I thought of that too Martyh, and I think it's a sound idea if you have access to good 6sn7's. How is the sound? and what trannies did you use?
#8 | |
My long term commercial reference is an ARC LS2, compared to that the sound was warm and full bodied but not in a bloated way. More musical is probably a good way to describe the difference. Vocals in particular had an uncanny realism compared to my reference, more of a “they are here” than a “you are there” presentation if that makes any sense I listened to it until my marginal filament supply died and rather than rebuild it I am using the output transformers for a version using the 26. I’ve set that up so that if I can’t get the 26s quiet I can switch back to 6sn7s using the unregulated supplies and call it a day. I’m hoping that the 26s give me more of the more I got with transformer coupling but I really enjoyed the 6sn7s and if I need to switch back I’m ready to call it day in my preamp search. |
#9 | |
cheers, Douglas
the Tnuctipun will return |
#10 |
Ditto, currently listening to a PP 6n6p linestage into amorphous Lundahl. Sheer bliss. What kind of problems? Those little tubes are like tanks; no noise, hiss, or hum, and never had a problem with RF or oscillation. They like their current, tho.
Not meant to distract from your topic. |
| thoughts about a 'universal' preamp | ErikdeBest | Tubes / Valves | 16 | 30th March 2010 08:56 PM |
| I want to build a preamp for my dad.. thoughts? | 240z4u | Tubes / Valves | 32 | 22nd April 2009 01:32 AM |
| Any thoughts on this Philly Audio preamp design. | Wtlng | Tubes / Valves | 8 | 14th January 2006 12:59 AM |
| Quick help needed! LOTs of noise in BBMCCCS loaded /0A2 regulated preamp! | stigla | Tubes / Valves | 17 | 12th May 2005 12:02 PM |
| Best BOSOZ preamp parts selection thoughts | hifimaker | Pass Labs | 94 | 23rd March 2005 06:47 PM |
| Page generated in 0.11222 seconds (75.06% PHP - 24.94% MySQL) with 11 queries |
