diyAudio Sponsor
Old 6th December 2009, 03:36 AM   #1
Default 12AU7 Amp?
I apologize if this has been covered before (I did try to search for a thread!) but could one make an amp using only 12AU7 tubes in class A or AB? or are they not powerful enough to be more than an linestage amp...
hmmmm........
Old 6th December 2009, 04:36 AM   #2
12AU7 is capable of pushing 5-8 mA of current. A Broskie Aikido with 12AU7 would make a mighty nice linestage.
Old 6th December 2009, 04:41 AM   #3
aardvarkash10's Avatar
if you have a 125db/w capable speaker, anything is possible...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 6th December 2009, 07:48 AM   #4
Tubes4e4's Avatar
Sure, f.e have a look at Tim Williams' "Hept'AU7" amp. If you want to go all 'AU7, you also can replace the driver 6SN7 with 'AU7 with little modification, if any.
http://webpages.charter.net/dawill/t...Hept%27AU7.gif
Tom Schlangen
If in doubt, just measure.
Old 30th December 2009, 12:28 AM   #5
I've been wanting to mess with the JJ ECC99 for years, but haven't found a good reason to try them. In the back of my mind, I've been picturing a headphone amplifier.
So instead of a zillion 12AU7 valves in parallel, how about some 6CG7? Take another step up (in size and power) and use a bunch of ECC99? Filament current would probably be an issue!
The 6CG7 is one of my all-time top favorite valves.
Either way, a bunch of small triodes in parallel with an EL84-style transformer will work. Edcor (and several other companies) make a 7.6k : 6 output transformer that would be great with a handful of ECC99.
Old 30th December 2009, 12:52 AM   #6
HollowState's Avatar
Tim De Paravicini got 20 watts per channel using only 12AX7s (10 per channel) in his V20 intregrated amp.
Stereophile: EAR V20 integrated amplifier
http://www.blackdahlia.com/tipindex/...3/tip__13.html
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 30th December 2009, 01:43 AM   #7
It would be great to be nearby when the US military scraps those old triode based supercomputers. Imagine all those ECC tubes
Gary
Old 8th January 2010, 09:21 AM   #8
jerluwoo's Avatar
Digging up this thread since it made me curious if a decent little amp could be made with au7's, and it doesn't seem as if the op got a decent answer. I used a maggie console amp 197-10 as the platform, originally a stereo EL84 amp. It has a 300 0 300 transformer with 5v and 6.3v taps, using the original 5y3gt rectifier and the small current draw of the amp netted a B+ of 320v before the rc filters. The OT's are 5.2k/3.2 ohm units, and I use a pair of pioneer cs-g203 speakers with a 6ohm nominal impedance,although strangely all the speakers in it are stamped 8ohm. I get about 1 watt out using both sections of the au7's in parallel in single ended fashion with about 295v across them and about 8ma current per section. It sounds quite good although a little lacking in the low end bass.
Old 8th January 2010, 12:17 PM   #9
yagas is offline yagas  Greece
jj ECC99 or 6H30 are more suitable
Hagerman Technology LLC: Cymbal Vacuum Tube Push/Pull Power Amplifier 6H30 6W DIY Kit
Mic
Old 8th January 2010, 01:55 PM   #10
Tubes4e4's Avatar
what´s the purpose of R7 and R8? Intended as grid stoppers? If so, just connect pins 2 and 7 with a wire as short as possible at the tube socket and use a single grid stopper of about 1,5...2,2k Ohms.
Regards, Tom Schlangen
Cycline3 on the 12AU7 Cycline3 Tubes / Valves 24 28th October 2007 04:20 PM
12AU7 instead of 6C4 Dr ZEE Tubes / Valves 9 3rd August 2007 02:25 AM
Question about 12AU7 pho_boi Tubes / Valves 3 3rd October 2005 06:00 AM
How about this 12au7 pre? sith Tubes / Valves 2 13th April 2004 08:27 PM
Wiring a 12au7 A3rd.Zero Tubes / Valves 14 1st April 2004 11:07 PM
Page generated in 0.11094 seconds (80.69% PHP - 19.31% MySQL) with 11 queries
