diyAudio Sponsor
Old 5th December 2009, 09:12 AM   #1
aardvarkash10's Avatar
Default 230-115V step down transformer earthing
OK following advice from a coupe of weeks ago (original post here), I bought a couple of 230V to 115V stepdown transformers to run a native 115V jukebox power transformer.
THE stepdown is a commerical item (ex-Korea) using a toroidal transformer. The 230V side was supplied through a two-core flex with no earth line (even though the case is steel!). I have since put a three pin IEC socket in the back and safety earthed the case. It is fused!
The output terminates at a pair of US pattern line outlets, and so again has no earth.
QUESTION: For ether safety or avoiding earth loops between the amp this will supply and source devices, should I fit IEC outlets and earth them to the safety earth?
Cheers!
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 5th December 2009, 09:52 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Does the juke have a connector that wants safety ground?
If it does, sure, otherwise I wouldn't bother.
Cambridge Audio Azur 640A toroidal power transformer (115V) limono Swap Meet 1 25th December 2008 04:57 PM
Can I use a step-up transformer as step-up? cviller Parts 5 6th September 2006 06:32 PM
WTB: Transformer - 115v pri, around 22v dual sec Ben_Tech Swap Meet 3 4th September 2006 12:46 AM
Transformer hook-up question to 115V AC line Joseph0 Tubes / Valves 10 19th August 2005 02:00 PM
Page generated in 0.07609 seconds (72.63% PHP - 27.37% MySQL) with 10 queries
