diyAudio Sponsor
Old 5th December 2009, 02:23 AM   #1
JandG is offline JandG  United States
Default Wiring a DPDT for direct in & 2-100k mono pots ..?
I would like to wire my DIY amp project for direct in as in full on via 100k resistors & switch to 2-100k mono pots when I feel the need useing a DPDT switch. I just am haveing a severe brain stop moment & can't see a way to wire it correctly for this...any help would be appreciated.
Joe
Old 5th December 2009, 03:33 AM   #2
aardvarkash10's Avatar
you need a 4PDT or two DPDTs. Diagram shows one channel only
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 5th December 2009, 03:51 AM   #3
godfrey is offline godfrey  South Africa
Hi
You want the switch to bypass the volume control? In the first diagram below, the pot still loads the input, even when not used.
If you want to totally disconnect the pot, you'll need a 4 pole 2-way switch (or a separate DPDT for each channel). Second diagram shows this for one channel.
Cheers - Godfrey
100k linear pots, any idea? edrel sison Tubes / Valves 4 8th March 2008 01:52 AM
WTB dual gang 16 mm 100K PC mount pots chipco3434 Swap Meet 0 9th December 2006 01:44 AM
i need 100k log pots brian marshall Parts 2 30th July 2004 04:23 PM
Need help wiring DPDT switch Static1 Parts 4 14th October 2003 10:25 PM
100K linear cermet pots HarryHaller Swap Meet 0 19th September 2002 07:18 PM
Page generated in 0.10054 seconds (64.31% PHP - 35.69% MySQL) with 11 queries
