low cost pre amp plans - Page 4 - diyAudio
Old 28th May 2003, 08:05 AM   #31
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Ok so even if the OPT isn't contributing any appreciable load, the other tube half is. Why is the CCS use at all, and why is it negated with caps?
Lesse... 6N6P mu circa 20 IIRC (was talking with Colt and he looked it up for me), but since the OPT's winding ratio is 40:1, or 20:1 for one half the transformer as is used here, net gain won't be greater than one. Though it will provide additional current if the signal source is high impedance, and adds a volume control to the string.
I bet if you changed the CCS to a resistor, and got rid of those spare caps (at the CCS and PSU), you'd have enough money to squeeze in a choke.
Lesse... 75mA choke... AES sells a 10H 90mA Triad choke, $18. As for the circuit, you can use the same PT and caps, paralleling the two last ones as shown. Should be good and solid and sim shows the same negligible level of hum.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 28th May 2003, 08:10 AM   #32
Hi John,
The inductance is a problem - one additional reason for more current through the triode to reduce Rp a bit more.... Using a cheap OPT one is always going to suffer with poor bass extension. The circuit actually cheats a bit - the 220uF yields a small tip up in bass response before it drops off - so subjectively the effect is a bit like the LS3/5a. This is fixed by using Hammond 1609s at another 50euros cost - it's also worth using a twin LC psu removing the decoupling caps and going true PP. Replace the pot with a TVA doing PP splitting and you have my own pre Well almost...
ciao
James
Old 28th May 2003, 08:18 AM   #33
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Calling Henry..
Hi James,
Well of course that's a very good reason for the 220u.
With Tim's proposal, the Rp would be much higher.
Anyway Tim, are you up early, or late to bed?
Old 28th May 2003, 08:19 AM   #34
Hi Tim,
Actually I tried that and it breaks the bank. Look at the cost breakdown and the two ccs costs a total of 1.3 euro...
Of course, the decoupling caps add up to the choke cost and one could throw them away - but I know the difference between having the Audyn bypassing the psu output and not and I wouldn't be without it - I think..
I don't think it's a perfect or even an optimum design - I thought it interesting to do a WOT pre for 100euros and interesting enough to post...
I hadn't intended to build this but I might knock this up with the psu your way to see what it sounds like and then try my way and see which works better as I really don't know which would be better.
James
Old 10th March 2017, 10:44 PM   #35
thank you everone
Old 10th March 2017, 11:53 PM   #36
kodabmx is offline kodabmx  Canada
A simple Aikido 6N3P preamp running off of a small high voltage module can be built for less than $100 and runs from a 12V supply. You might even be able to build it with 6N6P outputs and drive 32 ohm headphones with it.
Here's the module I use for my line and phono stages. A simple 2k/47u filter works well, the switching freq is 75 khz. You would need one per channel if building the 6N6P version (~40ma/channel@265v)
http://www.ebay.ca/itm/332079780531?...%3AMEBIDX%3AIT
This is a phono/headphone combo I built the other day for about $125 CAD.
Old 11th March 2017, 12:07 AM   #37
leadbelly's Avatar
2003?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 11th March 2017, 12:40 AM   #38
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
6N16B run from 12V can add nice clipping. :-)
The Devil is not so terrible as his math model is!
Old 11th March 2017, 12:46 AM   #39
nikon f is offline nikon f  United States
For $100 you could get the Bottlehead Quickie kit. It's fun to build, battery powered and sounds great.
Old 11th March 2017, 01:59 PM   #40
Yes it can! Luckily I use a 12V supply to power an SMPS to get my 300V
Best low cost BIB? Rick J. B. Full Range 32 1st October 2011 07:21 PM
Need for Low Cost RF MOS xitronics Parts 0 20th December 2006 01:45 PM
op amp cost pikkujöpö Digital Source 18 10th October 2005 12:07 AM
How much would this cost??? jazzius Multi-Way 0 17th February 2002 09:39 PM
Copyright ©1999-2017 diyAudio
