low cost pre amp plans
Old 27th May 2003, 03:51 PM   #11
James D. is offline James D.  United Kingdom
Default ...WOT? How about 100euro...
I had an idle 30 minutes at lunch to day and thought I would have a go at a 100 euro preamp with an OPT...
A few compromises are needed but I came up with this parts breakdown...
Hammond 125 PP OPT 12.5k:8R 125C PP www.tubes.it € 18.53 2off € 37.06
Power Xfmr 230V@12omA TRA200 www.askjanfirst.de € 14.99 1off € 14.99
Elec cap 100+200+200uF KON6005 www.askjanfirst.de € 2.67 1off € 2.67
6N6P www.askjanfirst.de € 7.89 2off € 15.78
noval socket www.askjanfirst.de € 1.86 2off € 3.72
BYV26E www.diyparadiso.com € 0.47 4off € 1.88
Ultrapath cap. Audyn 15uF 400V www.diyparadiso.com € 5.80 2off € 11.60
100k log pot stereo carbon Hi-qual. www.diyparadiso.com € 5.00 1off € 5.00
220R 4W metalfilm www.diyparadiso.com € 0.86 1off € 0.86
270R 4W metalfilm www.diyparadiso.com € 0.86 1off € 0.86
470R 4W metalfilm www.diyparadiso.com € 0.86 1off € 0.86
220K 2W bleeder www.diyparadiso.com € 0.24 1off € 0.24
TL431cp www.diyparadiso.com € 0.27 2off € 0.54
68R beyschlag www.diyparadiso.com € 0.10 2off € 0.20
68k beyschlag www.diyparadiso.com € 0.10 2off € 0.20
BC550c NPN transistor www.diyparadiso.com € 0.14 2off € 0.28
220uF 25 V Elna Cerafine www.diyparadiso.com € 3.66 2off € 7.32
Total € 104.06
The OPT is a compromise - but swop it for a Hammond 1609 and add 50 euros to the cost and it should be good. Of course it doesn't include switches input/output sockets or chassis...they are all in the parts box already
ciao
James
Old 27th May 2003, 06:18 PM   #12
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Hi James,
Does the second triode provide a bias current for the transformer?
I presume it's grid will go to ground through a resistor.
Old 27th May 2003, 07:42 PM   #13
Default ...Whoops!
John.
Thanks - good spot!!!
It does indeed on my sketches but I missed it on the .gif file. I did it all in a hurry today... there are probably other errors as I really rushed it but I thought the idea was interesting enough to post...
The second triode is for bias current - I first wanted to go push-pull so no decoupling at the cathodes but then I remembered that the psu sounds awful - it's cheap but awful so the fix for that was to use full decoupling at the cathode to remove the psu from the signal path.... and since the SE OPT are so expensive I decided to leave the second triode in as dc bias for the PP OPT...
It ain't pretty but it's cheap!!! Should sound nice too...
ciao
James
Old 27th May 2003, 08:08 PM   #14
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
How isn't it PP? Looks like you got a LTP there, so the other side will be the inverse of the first.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 27th May 2003, 08:18 PM   #15
dhaen's Avatar
Tim, you missed the 220u decoupler.
Old 27th May 2003, 08:52 PM   #16
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
8 euro for a 6N6P!?
I'll supply them for 4 euro
Old 27th May 2003, 10:02 PM   #17
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by Sch3mat1c
Oh you're just mad 'cuz it doesn't have an OPT
Tim
with or without OPT
it's just too wimpy
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 27th May 2003, 11:15 PM   #18
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Ok, alright already...we'll add a few 150H chokys.
Frank
Old 27th May 2003, 11:45 PM   #19
Sch3mat1c's Avatar
D'oh!
Well why the heck would you have it in then? More power and less distortion...wtf...
Tim
Old 27th May 2003, 11:52 PM   #20
fdegrove's Avatar
Why? Does anyone want more distortion and less power?
The SET guys might...
No, Tim, the idea is to be able to use a PP OPT iso the more expensive SE OPTs.
Frank
low cost pre amp plansHide this!Advertise here!
Best low cost BIB? Rick J. B. Full Range 32 1st October 2011 07:21 PM
Need for Low Cost RF MOS xitronics Parts 0 20th December 2006 01:45 PM
op amp cost pikkujöpö Digital Source 18 10th October 2005 12:07 AM
How much would this cost??? jazzius Multi-Way 0 17th February 2002 09:39 PM
