diyAudio Sponsor
Old 3rd December 2009, 12:05 AM   #1
tubo is offline tubo  Philippines
Default power supply filter choke current rating.
hey folks,
i have a 10henry 200ma filter choke. im breadboarding a power supply which requires a 10h 100ma choke. im using the 10h 200ma choke instead of the specified choke and im getting a higher voltage. do i need to stick with the 10h 100ma to get the correct voltage?
the power supply is poinz's 6v6 music machine.
http://www.diyaudio.com/forums/attac...lp-bog6gk5.gif
thanks
ivan
Old 3rd December 2009, 12:11 AM   #2
astouffer's Avatar
The 200ma choke probably has a lower dc resistance, thats the reason for the voltage increase. You could use choke rated for less current but the simplest solution is to add a resistor in series.
Old 3rd December 2009, 01:26 AM   #3
BZed is offline BZed  United States
How much higher is the voltage? If its within 5 - 10% it's not going to be a problem. The AC line will change more than that causing the voltage to change with it.
Are you testing the PS with a load on it? If not the voltage will be much higher than the loaded voltage.
Good luck BZ
Old 3rd December 2009, 02:26 AM   #4
im breadboarding all of the amp itself. i do have a higher incoming AC which is 125v and is causing the secondary to have a much higer voltage. the scheme of the amp is on the first post.
i replaced the first cap on the power supply which is 1uf with a .22uf which brought the voltage down to the correct voltage which is 340v from 390v.
will the lowish .22uf first cap create some problems?
thanks
Old 3rd December 2009, 02:58 AM   #5
do i need to put the resistor before the first filter cap or after and in series with the choke?
Old 3rd December 2009, 03:03 AM   #6
Good luck BZ
the PS supply is loaded.
thank you
Old 3rd December 2009, 09:24 AM   #7
In series with the choke, between the caps is ok. Remember to calculate the dissipation and use a resistor with about 3x wattage rating.
Old 4th December 2009, 10:50 PM   #8
With that much extra voltage its a good opening to build a regulator. A good regulator makes an amp work so much better it's always worth it in my opinon
Old 4th December 2009, 11:09 PM   #9
im having a different problem with the power supply again. now im reading 250vdc coming from pin 8 of the 5y3gt loaded. that is with the exact power supply values on the scheme and still with 10h 200ma choke.
im reading 400-0-400 volts on pin 4 and 6 of the 5y3 unloaded. and 530vdc on pin 8 unloaded.what is happening?
thanks
ivan
Old 5th December 2009, 12:14 AM   #10
thanks
ivan
Research the term 'critical current'. The properly loaded L-C filter will deliver .9x the rms input voltage( minus rectifier losses, and they're significant with type 5Y3 ).
cheers,
Douglas
the Tnuctipun will return
choke input power supply filter audionut Pass Labs 49 29th January 2012 05:38 PM
filter choke voltage rating nhuwar Tubes / Valves 3 28th October 2008 02:45 AM
way to estimate choke current rating? astouffer Tubes / Valves 8 15th October 2007 08:37 PM
Using Choke in LCRC filter in power supply vangogh-hk Tubes / Valves 5 24th November 2005 05:21 PM
choke current rating metebalci Tubes / Valves 17 9th August 2004 08:51 AM
Page generated in 0.12002 seconds (79.56% PHP - 20.44% MySQL) with 10 queries
