| diyAudio Sponsor | ||
Hello,
I found these DC modules that retail for about $200USD a pair. I was looking at the simplified schematic they provided on the website and was wondering a few things about them. Will you take a look at these for me and tell me if I can achieve the same thing with a self made module using a 78xx voltage regulator. Here: Tube filament supply As an experiment I was going to use the same thing I hand built from scratch for the KT88SE project I just finished, a simple rectifier bridge followed by a cap and voltage regulator and then another cap. Of course I provided DC to an indirectly heated filament tube (KT88) and I understand the DHT is entirely different. This production module appears to have a few more IC's as a current source and something else. They are very expensive, about $200 a pair. I wanted to make my own modules that simply converted the AC to DC. Can one still install a hum pot with a DC source to the filaments if I chose to make a simple rectifier/filter module of my own? What is the purpose of the other stuff in their circuit and is it truly needed? Best would be if somebody knew of a schematic that would provide me with the same results as these modules that I could just build myself for less $$$. Thanks for your help. Jeff |
#2 | |
With idhts i am quite happy using a 317 as a constant current source. Raw dc quality is still audible but it will probably remain so even with a high performance ccs. $200 for a ccs with automatic voltage control seems a bit silly. |
#3 | |
Jeff |
#4 |
Assuming your DC supply can handle being floated at the cathode voltage you're running, I don't see any issue with running a regulated DC supply for DHT heaters. That's been done before.
The humdinger pot should not cause trouble when you convert to DC. It probably won't do much, but I don't think it'll cause trouble either. With DC heaters, you have two options: Constant current or constant voltage. Both can be accomplished by an LM317. See Morgan Jones, "Valve Amplifiers" for more info. ~Tom |
#5 |
Ok, another question...the amp I am in the process of building the Hagtech Clarion 2A3
here: CLARION 2A3 Stereo SET Amp (follow link to article on that page) He is using 2 separate filament supplies for a balanced cathode drive and no hum pots. Is this better than a filtered DC supply on the filaments....am I gaining or losing anything by rectifying the filament heater supply? It just seems to me that a good filtered very low ripple heater supply would be better than anything AC, even this balanced cathode drive.....but I never fail to be suprised by what I learn. BTW this is my first DHT amp to build and I just want it to be one of the best I have built too. Jeff |
#6 |
I saved this file that was posted a while ago...
#7 |
astouffer,
Can this PCB be bought somewhere? Jeff |
#8 |
I'm in the process of making dedicated soft-start filament supplies and have boards on hand. They use LM317T for up to 1.5A continuous and LM338T for 5A continuous. I have a few blank PCB's ready and a lot more about three weeks mail away. Cheers! **edit** Added PCB schematic Last edited by Geek; 3rd December 2009 at 05:47 AM. |
#9 | |
Their module is floating supply input and then they *ground* the 'positive' output to the audio ground end of the filament. Hence their module's 'negative' output is towards the more positive end of the filament. Look at the diagram and notes on page 6 of their application note: http://www.tentlabs.com/Products/Tub...e_V01_AN02.pdf I do not know why they do that but the designer is intelligent so there must be a reason. In other words it is significant, and it is best be understand it before you can hope to DIY copy it. Anyone know why it is connected that way? |
#10 | |||
I know you Brits are 1 hour ahead of us so you must have still been very drowsy posting that
![]() What's good for the goose ... Quote:
Mmm, I think I should get into business of selling regulator boards at 5 times their actual value ... |
| B&O ICEpower modules – any built? | otto88 | Class D | 89 | 16th June 2011 10:39 AM |
| Twisted Pear My Ref Rev C built modules | Stuey | Swap Meet | 13 | 9th September 2007 12:31 AM |
| Expensive Commercial Amps | Bryan | Tubes / Valves | 27 | 21st September 2005 09:29 AM |
| Who Makes Pre Built Modules? | Zero Cool | Class D | 1 | 13th February 2005 06:51 AM |
| Page generated in 0.12114 seconds (80.03% PHP - 19.97% MySQL) with 11 queries |
