diyAudio Sponsor
Old 1st December 2009, 11:53 PM   #1
Default Sprague 183P Question
So I have a box full of old unused Sprague 183P capacitors. These have a stripe on one side. But they're not polarized right?
I also have a bunch of old Mallory caps , the big brown suckers, same thing, stripe on one side. GEM-601
And some Good-Alls too..again with the stripe...but I can use these in the signal path right? I know..silly newbie Q.
Old 2nd December 2009, 12:08 AM   #2
HollowState's Avatar
Yes, you can. The stripe signifies the outside foil end of the capacitor. Which only means that if one side were to be grounded, that is the preferred side. Otherwise it doesn't really matter.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 2nd December 2009, 12:20 AM   #3
Thanks!
Old 2nd December 2009, 12:45 AM   #4
kevinkr's Avatar
Depending on how old these caps are I would not recommend their use where excessive leakage would result in the destruction of an output tube.
I usually throw all of these types away when I encounter them if testing indicates even a uA of leakage current with 200V or so across them. To keep unscrupulous individuals from fishing them out of my trash and selling them on eBay I now destroy them.
Some of the early Sprague poly types are fine, goodalls seem to have the occasional problem with terminations opening, and American Radionic types while good sounding have this problem in spades.
www.kta-hifi.net
Old 2nd December 2009, 12:54 AM   #5
Im relly just using these in preamps and di boxes. Okay really silly newbie Q. How would I test leakage?
most are unused, but yeah kinda on the old side, prolly 60's??
Old 2nd December 2009, 03:13 AM   #6
Trout is offline Trout  United States
Trout's Avatar
According to SBE who now makes Sprague caps that is not exactly correct.
They had an article on their website that clearly stated the marking on their caps do not, nor have they ever marked the foil end. This included all Sprague film caps ever made.
I have a copy of the article someplace, but it does not seem to be on the current website.
Sprague capacitors woodturner-fran Parts 3 17th February 2008 06:29 AM
2 x Sprague 20,000 MF 40Vdc Caps jeffshort2000 Swap Meet 1 30th November 2007 02:22 AM
Sprague capasitor id morfeas Tubes / Valves 7 13th March 2005 11:44 AM
Sprague Caps 16000uF/50V WALTER BURKHARD Swap Meet 1 25th February 2005 05:42 AM
Sprague Cap caseaudio_an Parts 2 18th September 2002 10:53 AM
Page generated in 0.10066 seconds (78.22% PHP - 21.78% MySQL) with 10 queries
