| diyAudio Sponsor | ||
Hello Everybody,
I changed a normal concertina input stage to the attached schema. Problem is, now it's arcing on shutdown of the amp for a few seconds. It doesnt do it every time, but much to often. ![]() I suspect its the voltage in the capacitors, in combination with the constant current source, who tries to keep the set current going, and raises the voltage on the plate. It also happened on switch on, but I fixed that already by increasing the power-on delay from 15 to 30 seconds. Anyone a solution? A second question: Does a CCS need some break-in time before it sounds best? Because at first it sounded like greetings and thanks already, Paul |
#2 |
No. Your ears have got used to it.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
#4 |
it may be the caps weren't fully polarized
if so hope it has not burn any holes in the cap foils just a may be..........it could be that the caps were just low magnetized |
#5 | |
Electronic components (including cables) don't "break in". Some may undergo some rapid changes in the first few (milli)seconds of operation (caps and the like...) but other than that the only thing breaking in is your hearing. This process takes as long as it takes to talk your brain into liking the new sounds it thinks it is hearing. Others will disagree.
#6 | |
The amplifier without the ccs is in use for about a month or two without problems. So I dont think there's aything wrong with the caps. The arcing is in the tube...if it happens I can see light coming out of the internal structure, and hear a crackling noise out of the speaker. |
#7 |
Pauldune, my guess is...
at turn off the first tube stops conducting... the constant current source continues to pull current from the charged power supply capacitors... it *forces* current into the grid of the second tube... the curent flows in the second tube from the grid to the cathode to ground... not good! I have seen a forward biased diode placed from grid to cathode of the second tube to stop this problem. When the amp is operating normally the diode is reverse biased and not conducting. |
#8 | |
We must differentiate this from the 'hype and bull' marketing used by the namby-pamby audiophile companies who use 'extended break in' to cover up simple psychoacoustic aclimatisation. Indeed their lies are shameful. |
#9 |
Example of protection diode: More cathode follower stuff
Credit: J Broskie / TubeCad The same can be used in your amp. |
#10 | |
| Regulated PS with shutdown | AudioWizard | Power Supplies | 14 | 1st November 2005 10:54 PM |
| What does thermal shutdown sound like? | kneadle | Chip Amps | 6 | 18th January 2005 01:13 PM |
| arcing in rectifier tube | el capitan83 | Tubes / Valves | 8 | 9th January 2005 07:50 PM |
| OPA548 and shutdown | kafka | Chip Amps | 9 | 5th September 2004 04:26 PM |
| Shutdown noise | energyandair | Solid State | 3 | 10th May 2003 10:52 AM |
| Page generated in 0.12380 seconds (80.85% PHP - 19.15% MySQL) with 11 queries |
