#31 |
If what you're saying about ECC81s is true then you will measure 7 mA with -20V on the grid and 375V on the anode. Not that there is anything wrong with that either, it's just odd that tubes would differ from specifications so much.
Lower Ra and Rk if that bothers you to much. |
#32 |
I'm keeping the ECC88 version, so I dont have that problem anymore. It sounds great, and it looks like the arcing problem is history too. Thanks to all of you guys!!!
#33 |
I wanted to end this thread with the announcement that the arcing problem is definately gone. 1 little diode between grid and cathode did the trick! So if anybody feels an unstoppable urge to build a dc-coupled concertina with a ccs, this should do the trick.
I'm thinking about opening a new thread, with all the measurements including distortion and spectrumanalyzer shots in every stage of the amplifier, in a "ecc81" vs. "ecc88 ccs loaded" style. But I dont know if anybody would be interested.... If anybody reads this, and is interested, leave a message here, and I will make the thread... |
#34 |
I am pleased that you have a solution by way of the diode.
By all means start your new thread, as I am sure many people would be very interested. |
| Regulated PS with shutdown | AudioWizard | Power Supplies | 14 | 1st November 2005 10:54 PM |
| What does thermal shutdown sound like? | kneadle | Chip Amps | 6 | 18th January 2005 01:13 PM |
| arcing in rectifier tube | el capitan83 | Tubes / Valves | 8 | 9th January 2005 07:50 PM |
| OPA548 and shutdown | kafka | Chip Amps | 9 | 5th September 2004 04:26 PM |
| Shutdown noise | energyandair | Solid State | 3 | 10th May 2003 10:52 AM |
