diyAudio Sponsor
Old 30th November 2009, 09:55 PM   #1
Question Question - Output Trafo with CFB
Hi, tube folks,
There are some output trafos with CFB (cathode feedback). CFB is described as 8% - 15% of primary.
Question: does this means 8% - 15% of
a) primary impedance
b) primary number of turns
Thanks in advance for any suggestion(s)
Old 30th November 2009, 10:34 PM   #2
Sorry, a bit of clarification:
a) primary inductance
b) primary impedance
c) primary number of turns
Old 30th November 2009, 11:15 PM   #3
HollowState's Avatar
I don't think there is any real standard for this specification. It could be primary impedance or percent of total primary turns. But very doubtful it's inductance. The only way to know for sure is to contact the manufacturer and ask. If you had one in hand, you could make a simple low voltage AC test measurement to find out which. But my gut feel leans toward total primary turns because that's how UL screen taps are usually specified.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 30th November 2009, 11:31 PM   #4
hey-Hey!!!,
Dynaco advertised its CFB output by turns ratio. They claimed 15%, and it was just a bit over 17 if memory is still intact... The Chicago BO-6 is also advertised by turns ratio, and their BO-14 has no lableing as to its turns ratio( it is 10% by turns to the anode coil ). The a-a loading is also taken independantly of the CFB coil; the effective load is higher( 1.15^2*listed a-a load for the BO-6 for instance ).
cheers,
Douglas
the Tnuctipun will return
Old 30th November 2009, 11:59 PM   #5
pointy is offline pointy  United Kingdom
pointy's Avatar
it's turn in respect to the secondary winding (as a separate winding}
sorry dynoco but 7% would mean the amp needs less feed back
Old 1st December 2009, 12:14 AM   #6
pointy's Avatar
whoops............... i think that's of the second winding
it was used before the nfb was taken from the speaker out-put socket
diyers in the 50s would put their own on the out side of transformer with a bit of card and tape
now days i think its best to come off the speaker socket with a resistor and cap
even though this can change the impedance set-up.
Old 1st December 2009, 12:41 AM   #7
JLH is offline JLH  United States
JLH's Avatar
CFB is usually specified as percent of primary turns. In other words, a percentage of primary voltage that gets fed back to the cathode. (10% CFB for a primary with 2000 turns of wire would have a completely separate winding of 200 turns of wire.) I love using CFB with Class A pentodes with separate G2 supplies and Class A2 triodes. To me CFB beats UL connect in pentodes every time. You can also get some very good dampening factors with high Mu transmitting triodes too. Electra-Print and Edcor are very willing to custom wind what ever you need.
Rgs, JLH
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 1st December 2009, 10:04 AM   #8
revintage's Avatar
Hey,
Have a pair of Quad II´s on the bench. They have 10% CFB. Together with light Schadeing and a pair of high-Gm pentodes as drivers and original KT66 this means we can skip global feedback alltogether.
Brgds
Lars
Old 1st December 2009, 03:12 PM   #9
Rgs, JLH
CFB is U-L as far as the g2 is concerned( with fixed g2 voltage ).
cheers,
Douglas
Old 1st December 2009, 03:21 PM   #10
revintage's Avatar
Hey Douglas,
Think you will find this one interesting, written by D.T.N. Williamson and Peter J. Walker:
http://www.dc-daylight.ltd.uk/Valve-...perlatives.pdf
It might make you change your mind. If not, it´s anyway interesting reading from two gurus of that time.
Brgds
Lars
Got a big output trafo I want to use. lawbadman Tubes / Valves 27 29th October 2008 04:14 PM
GU-50 output trafo croccodillo Tubes / Valves 7 11th May 2007 08:55 AM
Output trafo for WE-91 L'Audiophile amp? WE91 Tubes / Valves 81 19th March 2007 11:34 AM
PP Output Trafo Measurement jkeny Tubes / Valves 8 6th February 2007 08:29 AM
Page generated in 0.11791 seconds (74.34% PHP - 25.66% MySQL) with 11 queries
