diyAudio Sponsor
Old 28th November 2009, 06:11 PM   #1
nicoch58's Avatar
Default tamura f-7000 series
HI
I need some info on this trafo , any one have in use ?
alternative to Eifl for put an order ?
thanks
Old 28th November 2009, 11:47 PM   #2
kevinkr's Avatar
I've considerable experience with the amorphous core F-5002, and have encountered the F-7000 series in a customer amplifier. These transformers are very good, certainly amongst the best I have ever worked with. EIFL is a good source - all of the F-5002 I used in my amplifiers came from this source along with some custom built Tamura power transformers.
Highly recommended.
Edit: Since you live in Italy you might also want to consider Bartolucci, in my experience (limited) they have also been excellent. They have an extensive line of SE transformers, and I think you will find one of their higher models to be comparable in quality to the Tamura.
www.kta-hifi.net
Old 29th November 2009, 02:33 AM   #3
Default Tamura F5000 series
Hi Kevin:
I still have a pair that I used in an amp a while ago. Great highs/mids - actually amongst the very best. But bass was mushy, ill defined. I think the design lacked proper inductance to handle lows properly.
Mind you, the bass problem is relative to the fantastic highs and mids, I could easily live with them for a long time. But, having heard some things which cover the full bandwith, well it is hard to go back.
Jon Ver Halen
Lowther-America
Old 29th November 2009, 08:04 PM   #4
nicoch58's Avatar
kevinkr thanks but after tre mail at eifl no answer....
Jon "having heard some things which cover the full bandwith," can you explain better ?
if you have inused pair 5003...send a pm
Old 29th November 2009, 08:12 PM   #5
nicoch58's Avatar
I have all lundhal iron the opt is at 5k with eml xls300b.
any experience on tango/tamura choke? the LL are quite good and can be config as dual ,like CMC choke but I read that nikel on choke is good thing...
Old 29th November 2009, 08:14 PM   #6
disco is offline disco  Netherlands
disco's Avatar
This Dutch dealer keeps stock.
jaap
Old 29th November 2009, 08:17 PM   #7
nicoch58's Avatar
thanks disco but the price is 2X
ps stepup from tribute 4week nice!
Old 29th November 2009, 09:58 PM   #8
kevinkr's Avatar
Originally Posted by Jon Ver Halen View Post
Hi Kevin:
<snip>
<snip>
Not necessarily, there are so many things that can go wrong in amplifier design starting with the use of cathode biased output stages, high impedance power supply design (likely with CLC or CLCLC type supplies and tube rectifiers), and the speaker's dependence on high damping factor for good bass performance.
Substituting that OPT with something else with no further changes and getting a much better result might be proof that the transformer itself was the culprit, short of that, and without seeing the schematic or knowing more about the particular design it is hard for me to know.
My experience with the F-5002 and some limited experience with the F-7000 series stuff leaves me wondering if there isn't more to the story. Mushy bass is not the impression of bass performance I have gotten with any Tamura output transformer I've used.
www.kta-hifi.net
Old 29th November 2009, 10:06 PM   #9
disco's Avatar
Import taxes and shipment costs would explain that.
Pieter knows his stuff, good choise.
jaap
Old 29th November 2009, 11:23 PM   #10
nicoch58's Avatar
hi kevin , looking around the 5000 series is more critial to use as you write is not plug and play opt
5002 have lower induttance 18H vs 25H of 7002, this can be one ?
WTB Tamura 5k SE nicoch58 Swap Meet 1 10th December 2009 04:43 PM
Tamura HM-1 fxsound Tubes / Valves 2 20th July 2009 07:42 AM
Tektronix 7000 or 11000 series or ..? Speedman Parts 15 7th July 2008 01:40 PM
About TEK 7000 series scopes poobah Equipment & Tools 18 2nd September 2006 01:03 AM
tamura opt need help robertc Tubes / Valves 11 9th January 2005 04:12 PM
Page generated in 0.93156 seconds (13.78% PHP - 86.22% MySQL) with 10 queries
