diyAudio Sponsor
Old 25th November 2009, 03:23 PM   #1
paba is offline paba  Canada
Default formula help
Hello,
I was wondering if there is a formula that would allow me to calculate the -3db point change in bass response if I increase the cathode bypass resistor from the current 100uF to say 270uF changing nothing else? I have the values for the tube (mu, etc) and cathode resistor as per the diagram below (6N1P tube). I assume this change will lower my -3db point from some value down to some new value and before spending on caps I just wanted a ballbark idea to see if it was worth it.
paba
Old 25th November 2009, 06:24 PM   #2
You'll have to get out your calculator, since there are several variables in the expression. I'm going to do this with an image, since ascii math is cumbersome for this sort of stuff
If you need to know more about the net impedence of the cathode resistor/bypass capacitor parallel circuit, say so and I'll continue when I get home from work.
Aloha,
Poinz
Old 25th November 2009, 07:08 PM   #3
Merlinb is offline Merlinb  United Kingdom
Originally Posted by paba View Post
Hello,
paba
Unfortunately it is not so simple! Where cathode bypass caps are concerned, there is not always a -3dB cut-off frequency in the conventional sense, because the gain of the stage does not fall indefinitely. Depending on the valve used, and the value of the resistances, there may be less than 3dB difference between the unbypassed and fully bypassed levels of gain!
A better way to define it is by the 'half boost frequency'. The formula for this is given in this article:
http://www.freewebs.com/valvewizard2...BypassCaps.pdf
Old 25th November 2009, 08:19 PM   #4
I think this excel sheet will do what you want. Look for tubeformulas.xls
joeltunnah.com
otherwise formulas.xls on this page
http://www.vt52.com/diy/tips/tips_software.htm
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 26th November 2009, 02:29 PM   #5
Ok thanks all,
I will get by abacus out and pencil and paper and see how far I can get.
I don't have my Welborne schematic here now to get some of the Resistor values needed as inputs.
cheers
paba
Old 30th November 2009, 07:21 PM   #6
ok,
spent more time on this and found this on a web site..
"If the bypass capacitor is used, its value can be determined using the capacitive reactance formula see *below, and the value of Rk. You must decide what the frequency response of the cathode-bypassed circuit will be. The formula tells you where the response is down by 3db.
*f = 1/(2pi x Ck x Rk) and Ck = 1/(2pi x Rk x f)
As an example, for a 500-ohm cathode resistance and a 70Hz 3db down point, Ck is under 5 microfarads. "
So punching in the values I have in my DRD amps today...
gives be a -3db frequency of 10.6 Hz for that 6N1P first stage.
changing to a cap value of 220uF just as example, would mean a -3dB point of 4.8Hz
330uF -> 3.2 Hz
390uF -> 2.7 Hz
Well, I conclude that it isn't the difference between 10.6 Hz and 4.8Hz that will make the cows come home. Although I suppose that I could implement a quick toggle switch to alternate between two cap values and see if it is even audible at the speaker end.
Source:
Cathode-Bias and Fixed-Bias Switching in Tube Power Amplifiers
Old 1st December 2009, 02:37 AM   #7
5-6Hz is plenty low enough, so 220 - 270μF will get you there as well.
Aloha,
Poinz
box formula crs1 Multi-Way 29 23rd January 2008 09:53 AM
Q formula PeteMcK Multi-Way 10 17th January 2008 07:42 PM
gain formula xplod1236 Chip Amps 1 6th April 2004 04:47 PM
Need help on x-over formula Jay Multi-Way 3 12th August 2003 05:28 PM
Anyone have the formula for... Rino odorico Multi-Way 4 22nd January 2003 04:07 PM
Page generated in 0.10542 seconds (77.12% PHP - 22.88% MySQL) with 11 queries
