diyAudio Sponsor
Old 23rd November 2009, 02:03 PM   #1
Mosquito's Avatar
Default Chassis Layout Advice
Hi everybody!
Well, I think that I'm definitely a medium / low watt Push-Pull supporter. Really deeeply like all those amps like El Cheapo, Baby Huey, RLD, Frankenhouse and the genre.
Even if maybe in the future I'll able to put together one of my own design, sure it will be of a similar topology.
So I'm thinking about to develop some kind of standard chassis and layout that can accomodate this type of amplifier.
The picture shows a very preliminar effort, but I'd like some advise, letting aside the asthetics, in regard the convenience of the showed phisical disposition of parts.
Many tanks
JJT
Old 23rd November 2009, 04:09 PM   #2
Mosquito's Avatar
Ahemm, I'm very sorry for the typo at TD title, gentlemen.., maybe some gentle moderator can fix it..
Old 23rd November 2009, 08:09 PM   #3
pointy is offline pointy  United Kingdom
pointy's Avatar
with a chassis like that i would go for a radford tea trolley type set up.
with the power transformer and choke under a mesh box in the middle and each channel on either side.
but you would need to find space for the gz/ez tube if you use one.
Old 23rd November 2009, 08:41 PM   #4
m6tt is offline m6tt  United States
Generally it's best to have the power magnetics as far from the signal magnetics as possible. I can't really tell if you've done that there, but I'd do something like power magnetics (shared) in the center, with OPTs and other signal magnetics on the edges with the tubes in between. That being said, it looks like the rotation of the transformers *should* prevent coupling. I believe it is somewhat transformer dependent as to how close they can get before coupling. Pointy's steel mesh shield sounds like a good idea, but I am not familiar with the aformentioned tea trolley ! I know we like to see our tubes, but taking a hint from RF equipment, I am surprised more high quality amps don't have preamps, power stages, and magnetics in closed, divided steel compartments.
Old 23rd November 2009, 09:14 PM   #5
Mosquito's Avatar
Thanks for the opinions, very much apreciated. As for the tea trolley, I suspect is some Brit thing used as image of how was the layout of some Ratford amp . I'll Goggle "Ratford" pictures to give me an idea.
Thanks again.
JJT
Old 23rd November 2009, 10:18 PM   #6
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
I really like the color of your power trafo. Did you paint it? and if you did can you tell me the name of that grey?
Old 23rd November 2009, 10:44 PM   #7
Mosquito's Avatar
Yes, it's painted with aluminium primer, cause I don'like the original glossy finished metal bells.
I'll finish the OPTs same way.The product is a german made coat.
Duplicolor
Motip Dupli GmbH
Hassmersheim
product code 557255
If you are based in Madrid, you'll found it at Leroy Merlin stores.
PD: Pointy, I'm sorry it seems that I'm not in one of my smart days, of course the name is "Radford" not Ratford..
Old 23rd November 2009, 10:58 PM   #8
Cassiel's Avatar
Thanks!
Old 25th November 2009, 01:09 AM   #9
Molloy is offline Molloy  Europe
Account Disabled
The amp would look better if the two OT are facing the same direction. Donīt expect hum problems because of this.
Old 25th November 2009, 06:39 AM   #10
chrish is offline chrish  Australia
chrish's Avatar
Morgan Jones gives good advice on this in "Building Valve Amplifiers". In summary, I believe what he says is that you try to keep the small signals away from the big currents and magnetic fields. To that end your amp would be (from front to back) small signal tubes, output tubes, output transformers, rectifier tube and then the power transformer and choke at the back of the chassis. The way you have it laid out now, you are going to have to have high voltage lines going from your power supply past your input tubes to the output transformers.
Layout is more than just the interaction of the magnetics. Think about the voltage and current of all the wiring and how it will interact with the signal.
Also, don't forget about the heater wiring - tightly twisted right up to the sockets and tucked in to the chassis corners etc.
Chris
Need help with chassis layout bluegti Chip Amps 2 21st December 2008 01:32 AM
Chassis layout? Psychobiker Tubes / Valves 0 12th March 2008 11:12 AM
Chassis layout help Evenharmonics Tubes / Valves 4 3rd March 2008 11:52 PM
Chassis Layout & PS questions Valvomaniac Tubes / Valves 3 11th April 2007 07:46 AM
help with chassis layout jarthel Tubes / Valves 5 27th June 2006 04:41 PM
Page generated in 0.11223 seconds (76.31% PHP - 23.69% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
