diyAudio Sponsor
Old 22nd November 2009, 06:46 PM   #1
m6tt is offline m6tt  United States
Default What to do with these parts?
I am redoing a bunch of the equipment in our "music" room. We have a medium power tube amp or two, but I've decided to redesign the "PA", which was used for bass, keys, guests and vocals (wide response expected for MI amp, I guess). Here are the parts:
-6x 6P3s-E beam tetrodes
-A big 100W Marshall replacement OPT (1900 ohms, tapped for 4,8,16)\
-A handful of 20w OPTs (generally 5k-10k to 8R)
-A huge 1959 organ chassis with 10 octal sockets, and 5 noval, a 40w OPT is already onboard (5k).
-The associated power transformer is very large, core is about 4"x5"x6", provides two B+ windings (I believe one is a tap on the other, however) and 12.6v. I think the transformer powered mucho outboard equipment on the original organ.
-A handful of smaller PTs, various voltages
-A bunch of preamp tubes
-A nice heatsink with two 450v BJTs (2SKsomethingorother) from a computer supply
-A variety of chokes
Any ideas for what kind of design I should pursue? I don't think I can do a circlotron style output, since the one B+ winding is actually taps on the bigger winding. I am thinking that a bipolar supply might be of use, so I can use a direct coupled driver for both sides of a conventional push pull. There's no easy way that I can think of to use the smaller OPTs to drive the power stage, I think. I just read in Radiotron about neon-coupled designs, which I have never seen (possibly noisy?). Anyways, this is just a big parts bin project for sunday afternoon (and probably onward ). Ideas much appreciated!
Thanks,
m6tt
Old 23rd November 2009, 09:36 AM   #2
I decided on a push-pull parallel, 3x 6p3s-e per side. Cathode bias via 200-ohm resistors each all connected to a 75-ohm 1-amp ceramic rheostat (huge), which should give something like the equivalent of 0-700 ohm adjustable bias. Equal filaments per side of the 12.6 winding, second side of each tube heater connected to ground via cathode resistors (thus biasing cathode with dc and getting 6.3v per tube). Cathodes are fused at 1.5 amp per side. Screen supply is taken from inside B+ taps, not sure if I need to put resistors in like the SVT. Will probably use some form of cathode feedback in addition to slight global feedback.
Haven't quite finished designing the driver, but I intend to drive each side's grid with an IRF820 source follower, driven by a 6CG7 floating paraphrase. That leaves me with 3 noval and 2 octal sockets, probably do a push-pull 6SN7 or SE 6EM7 for the reverb. Outboard chassis with the input jacks etc has two more noval sockets. I do have a NOS 6L7 and some input xfrmrs, so a 50s RCA mic/guitar preamp ain't to far, but probably will end up with something simpler.
Power supply isn't totally designed yet, but I decided against a bipolar supply for many reasons. Plus I prefer cathode bias, it's cold lately . Solid state rectification is a certainty, into a 680uF bank of computer power supply caps. Hopefully that'll be enough. Got a bunch of 4k7s for the preamp dividers.
Speakers are a mix mash, right now they'll probably be a series-parallel 2x12 + 2x15. If I recall it's something like two Utah 12s, a CTS 15 and a peavey black widow HD.
*eventually* this will be the HF/upper mids driver with an eventually modified Flame linear 700b driving the peavey cab for bass (currently empty). Time for more math to see if I can run it B2. As is, it ought to handle small shows or a rockin' party. Makes a mean boat anchor, in any case...estimated weight is somewhere between 60-80 lbs .
Old 6th December 2009, 11:42 PM   #3
Alright, so I'm still working on this thing. I had tried and failed to get a 6AV5GA cathode follower to drive each side. So I swapped those for two IRF820 (actually the higher capacitance NTE knock-offs locally available ). It amplifies music, but there are some disturbing circuit conditions I can't explain. Total plate supply voltage is 505v. One side's anodes seem to be at 660v. Cathodes are all around 45v. One mosfet seems to drive about 6v higher than the other...oscillation? The OPT is a strange beast, actually 1700CT. Center tap is white, plate leads are red and blue according to manufacturer. DCR is not equal.
I've attached a schematic of the power stage. Comments, criticism, and screaming hate mail welcome:
Old 6th December 2009, 11:52 PM   #4
I wanted to make a quick explanation of my understanding of how the biasing works here...First off the power transformer is back biased by a giant 60 ohm resistor mounted to the chassis, near where the fan will be. This gives me a -10v quiescent supply. The power tubes are cathode biased up to 45-50v via the resistor network in the cathodes. The potentiometer (a giant ceramic rheostat from a motor controller) takes a small amount of voltage to provide bias for the mosfets (approximately 10v). The mosfet sources tie to the -10v supply through a 10k resistor. Since they are DC-coupled, the rheostat sets the Vgk by adjusting the amount of V on the mosfet gates. Current conditions are something like 20-30v Vgk after the circuit settles.
Old 7th December 2009, 12:03 AM   #5
SY's Avatar
I'll be surprised if this doesn't oscillate. You definitely need grid stoppers and you may well need some small inductors in the plate leads to keep things calm.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th December 2009, 12:42 AM   #6
Will grid stoppers prevent AB2/B2 operation, or just limit the power dissipated in the grid somewhat? How many turns on the plate leads do you recommend? I had plenty of space in this chassis for good lead dress, and all grid wires are shielded or twisted pair, screens and plates are twisted together (that seemed good to me, not sure though). Everything is point to point and "layered" away from each other in 3 dimensions with perpendiculars etc. No AC on plates or screens w/o mosfets, but Vgk is about 40v in that condition.
Audio sounds clear, I am using a heavily used 30w 70v PA head to drive the mosfets during testing. If it's oscillating, it's oscillating very high frequency. I'll try to rig up an RF detector for the mulitmeter and check. Not getting RF burns from the secondary or nearby grounded metal surfaces, at least! There was much less "stray" AC on screens plates etc. before the mosfets were added. I am thinking its the mosfets oscillating, and some screen related oscillations perhaps.
The plate voltages on the side where they read wrong start out at 550v, as current is drawn drop to 495, and then as the tubes turn on ramp up to about 660v. I suppose RF might read as DC to a bad multimeter such as my own.
Old 7th December 2009, 12:51 AM   #7
SY's Avatar
For a normal-sized grid-stopper, there won't be much of a limit to AB2 or grid current- something like 1-2k is typical. It forms a low pass filter at the input.
The plate inductors are trickier and very much depend on layout. Sometimes, they're just used on the tubes with the shortest leads to the output transformer. A few turns around a 100R 2W carbon comp would probably do it.
Old 7th December 2009, 01:32 AM   #8
Thanks SY...I'll post back again after trying a few things to keep the hams happy. Here's a revised schematic with grid stoppers, some corrections & the (mostly) DC-coupled preamp as well. Any comments welcome!
Old 7th December 2009, 02:09 AM   #9
Grid stoppers on the side that had incorrect voltages have already fixed the problemo. Hadn't even put in the grid stoppers on the other side yet. Ended up using 1k, since I had 5x 1.5k (one short...). Grounded the shielding on the grid wires between each tube as well instead of just both ends of the bus.
Is there an easy and safe way to make sure both my mosfets are still working? I did my best to limit their exposure to static electricty etc. but I guess I'm paranoid about NTE stuff anyway.
Old 7th December 2009, 08:34 AM   #10
Arnulf is offline Arnulf  Europe
You mean other than simply plugging in some music and listening to it ? This is why I always keep a cheap speaker around and it's still alive Worst case scenario they are blown and would impose DC on the speaker, which can be measured easily. Put 50/60 Hz audio on the input just in case if your voltmeter doesn't take RMS AC readings so you get more predictable results.
I don't think I have ever used NTE parts but to put your mind at least somewhat at ease: input capacitance of cathode follower isn't all that horrible as there is no Miller capacitance to contend with (actually there is some still, but it is negligible).
WTB: RGR Model IV parts or parts unit dnewma04 Swap Meet 2 1st January 2010 09:00 PM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
Trade your DAC parts for chip amp parts jeff mai Swap Meet 3 12th July 2004 03:51 PM
Comparison of SMD parts to standard parts BrianGT Parts 0 2nd July 2002 09:09 PM
Page generated in 0.13872 seconds (77.29% PHP - 22.71% MySQL) with 11 queries
