diyAudio Sponsor
Old 22nd November 2009, 12:33 AM   #11
Gordy is offline Gordy  United Kingdom
Hello Pointy, if you mean as the output transformer then you will find it to be virtually useless in that role.
Also, the circuit as illustrated was likely documented to show that which is theoretically possible. However, as has been stated above, it is not a very useful circuit in real terms.
If you configure your test box to be able to tackle common cathode, cathode follower, SRPP, long-tail pair, and cascode then you will have many interesting nights of experimentation ahead of you.
... and just forget about that particular Broskie circuit!
Old 22nd November 2009, 01:05 AM   #12
pointy is offline pointy  United Kingdom
pointy's Avatar
it was something more to wire up to a selector switch............
as i say it should be safe to try a few things......and the pre-amp build with the se power amp have only cost me about £30 to £40s so far(all i have left to do is fit the RCAs and 2 more pots).
What i'm doing is hav'ing a look at all the types of circuit that i may like to use (switchable)
in a stereo pre-amp one day(not X over because that can be done with a graphic equalizer), so i thought i would try them all out on the cheap to start with.
PS thanks gordy....................................that looks about
Direct-coupled cathode/source follower driver in PP? ray_moth Tubes / Valves 83 17th July 2008 03:53 AM
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 04:30 PM
417A-300B Plate Choke or Interstage Coupled? sgerus Tubes / Valves 21 14th January 2007 01:45 AM
Power follower class A Mosfet DC coupled. Mr. Steve Solid State 30 15th February 2006 07:04 PM
Plate follower and applications tiroth Tubes / Valves 15 21st April 2002 09:15 PM
Page generated in 0.07083 seconds (67.02% PHP - 32.98% MySQL) with 10 queries
