diyAudio Sponsor
Old 27th December 2009, 11:59 AM   #31
Originally Posted by Tony View Post
may i know your operating point for the 6H30?
hey Tony,
It has the MOSFET gate at ~110V and is passing 15 mA at idle per triode. It is arranged as a LTP over a CCS, and I don't worry about the value of the bias; that takes care of itself. B+ is over 550V, and the MOSFET drain is ~330V( all from ground ). It can take a 6H6pi with only a slight reduction in gain and these are generally better matched section-section( not to mention being much cheaper ).
cheers,
Douglas
the Tnuctipun will return
Old 27th December 2009, 04:23 PM   #32
Default Yes Yes Yes
Originally Posted by Gary P View Post
A variation I've tried with pentodes and will be trying with cascoded triodes in the near future is to put a very good CCS on top of the upper cascode element and connect the plate resistor to ground. The CCS provides all the current for both the cascoded triodes (or pentode) and the plate resistor. This shortens the signal path to include only the cathode resistor, the amplifying element and the plate load. The CCS provides very good power supply isolation.
For an example look at the "driver experiments" section on my web page.
Gary,
after reading your driver experiments page I had the same idea except to use a hybrid cascode as per AW. Even to using 2 or 3 MAT02 on the bottom for huge TransC. Then with a mu output impedance of circa 500R it is almost ideal to drive a 600R LCR riaa.
Cool
tim
PS AW would call this vapourware (I think)
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Strange LTP cascoding circuit roender Solid State 3 11th June 2007 10:23 AM
Cascoding X Aleph macka Pass Labs 2 30th September 2005 10:36 PM
On the Subject of Cascoding GRollins Pass Labs 19 17th September 2003 01:32 AM
ZEN V4 cascoding ??? ergo Pass Labs 23 9th July 2003 05:39 PM
Page generated in 0.09960 seconds (61.38% PHP - 38.62% MySQL) with 11 queries
