Test & Measurement interface for Soundcard - Page 61 - diyAudio
Old 31st August 2012, 08:08 AM   #601
Hi, AndrewL,
No problem, but I can do it only tomorrow.
BTW, I don't have foil shield inside yet.
Old 1st September 2012, 04:36 PM   #602
Originally Posted by AndrewL View Post
Hi Linksguru
Could you post an picture of the inside of your box?
Andrew
Hi, AndrewL,
Here are the pictures of assembled PCB.
Additionally, as many forum members suggested, I grounded shaft of rotary switch, 50 Hz noise went down by -4dB. Closest ground point is R11 (see red wire on photo).
Test in loopback mode (input and output connected together on 33K resistor terminals), 1.9V sound card out, 96KHz, attached.
Old 1st September 2012, 04:58 PM   #603
I would like to add a not to ESI Juli users. Although sound card itself is very good, its seems it works better (in this particular application) in 96KHz, not 192 KHz mode. I don't know why, I suspect high-frequency noise picked up by SCI.
So next step will be to building foil shield inside plastic box.
At a glance, precision looks very good (0.0025% THD, 0.014% THD + N @ 1.9V/1KHz), but it is actually not so. Due to the noise (or some other reasons), it is not possible to precisely measure THD at small signal level, e.g. 20mV, and precision at 20 KHz limited to 0.05%.
I'm attaching tests in loopback mode, 20Hz - 1KHz - 20KHz, 1.9V output from ESI Juli (balanced connection), 96KHz sampling rate.
Old 1st September 2012, 07:33 PM   #604
klewis is offline klewis  United States
klewis's Avatar
At 96khz you should be able to measure out to about 45khz. At 192khz, out to about 90khz. There is a setting in Arta that will allow you to expand you window to view these higher frequencies.
Second, learn to used the averages function for fft. It will smooth your response lines. I would Start with 25 averages.
Ken
Old 1st September 2012, 08:39 PM   #605
I know about expanding graph ranges/window - if you look at my attachment, they display charts in 10Hz - 30KHz ranges instead of standard 20Hz-20KHz.
Averaging turned on - it is clearly visible on top menu bar.
Old 1st September 2012, 09:18 PM   #606
TheGimp is offline TheGimp  United States
TheGimp's Avatar
A better choice for shielding is Mu Metal (I used UltraPerm) instead of Al foil. Al foil will work as an electrostatic shield, but not a magnetic one. Ultraperm is available from the usual source (ebay) at a reasonable cost.
Just be careful with Mu Metal shield. You don't want to bend it or the stress reduces the permeability from the annealed state. It cuts with a heavy pair of scissors.
Old 2nd September 2012, 12:46 AM   #607
dirkwright's Avatar
You can get ultraperm on eBay. In the past, it's been available at the electronic goldmine. It's self stick mu metal.
Old 2nd September 2012, 08:26 AM   #608
AndrewL is offline AndrewL  United Kingdom
I like the Jukli@ but couldn't get the averaging working relaibly enough, to much driver latency; it could have been the PC. I wanted to free up the PCI slot anyway so I switched to an EMU 1212 PCIe. Patchmix driver control is not intuitive so it took a while to set up correctly, but it seems very fast now, no latentcy problemes.
Andrew
Old 2nd September 2012, 08:55 AM   #609
Andrew
Nope, its not PC. I have Quad Core with 4GB RAM. It looks like a driver latency problem, you can see it on my charts attached, averaging doesn't work well.
BTW, did you solved oscillation/noise problem with SCI?
Old 2nd September 2012, 12:49 PM   #610
dirkwright's Avatar
The board does have a ground plane in it, so I guess extra shielding may not be completely necessary.
Recommendations on pc audio interface for loudspeaker measurement diypole Multi-Way 9 15th July 2009 12:45 PM
Request for advice / high performance soundcard for measurement Gordy Solid State 8 14th February 2008 04:14 PM
MCM Speaker Measurement Interface / USB Woofer Tester sdclc126 Multi-Way 0 17th January 2007 01:00 AM
Tenma Speaker Measurement Interface johngalt47 Multi-Way 1 6th January 2007 02:17 AM
Soundcard interface. Mr Evil Everything Else 5 12th July 2005 11:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
