Test & Measurement interface for Soundcard
I suggest that instead of removing D10/12, D11 / D12 be replaced by a string of 1N4148 diodes the number of is suitably selected to put the protection limit closer to the full scale voltage of the soundcard YOU are using.
Note: I got better THD (flatter increase) vs frequency by using THAT parts for the line recievers/drivers) (see posts a few pages back)
Did you mean replace D11 / D13?
Here are some amp measurements before I static shocked my 2i2 to death :/ This is an emotiva Mini-X A-100 at -3db from max output, about 26 WPC @ 8 ohms
USB vs Battery power
attachment.php
attachment.php
About the lamps.
The link does not work (anymore), and so I think you must mean these:
12V Microlamps (2-Pack)
Model: 272-109, Catalog #: 2721092
I have some X-Mass ornament micro lamps left and will try those.
Tks!
I just switched these to xmas lights since they're meant for 120v and I didn't realize I grabbed the 12V lamps from radio shack... not that I think it will make a terrible difference, but I was curious.. They both end up measuring the same.
Make sure you use 120V bulbs... low-voltage bulbs have such low resistance that they won't provide any overvoltage protection.
Pete
Hallodeletue, I see from your picture that you use little circuit boards with chips on them in place of the input resistors. Can you share that circuit with us? Is it better/equal to using lamps?
I also see a mod north of the DC-DC convertor, probably dealing with the DC input voltage. Care to share that with us?
Tks,
Paul
