diyAudio Sponsor
Old 20th November 2009, 06:19 PM   #1
KT is offline KT  United States
Default Where to find large capacity high voltage caps?
Hi
Where should I go to find 1800uF 400v electrolytic caps for PS use?
I'm also looking for 150uF 400v.
I'm looking for those specific values.
Most of the suppliers I've looked at have some high voltage caps, but the 1800uF 400v is hard to locate.
Is there a manufacturer or brand in these high value caps that are known to be better performers sonically? Or is it a case of them being so hard to find that you just have to use what is available?
Thanks!
KT
Old 20th November 2009, 06:34 PM   #2
JimJ is offline JimJ  United States
Capacitors at The Electrostore.com - Electronic Surplus Parts & Equipment
No idea if they're a reliable source, but looks like they have 1800uF @ 400V.
150uF @ 400 is easy
150uF 400V Snap in Capacitor
Old 20th November 2009, 06:38 PM   #3
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Gah, I typed in the wrong user name again, I forget that one is still active
Anyway...looks like Digi-Key carries 1800uF/400Vs, just not as a regularly stocked item...
http://search.digikey.com/scripts/Dk...name=P13190-ND
Jim J.
Old 20th November 2009, 09:33 PM   #4
Originally Posted by KT View Post
Hi
Thanks!
KT
Here you are with one of the best capasitors ever made. Nippon Chemicon 1800uF/400 105 degree. Is mentioned to be one of the best as far as sonical performance is concerned.
Schraub-Elko Nippon 1800uF / 400V ; 1800µF + Schelle bei eBay.de: Bauteile (endet 09.12.09 14:27:49 MEZ)
Best rgds
Kim
Should have 150uF/400V as well. Otherwise try Ebay.de. I think they accept PayPal.
Old 21st November 2009, 06:36 PM   #5
samking is offline samking  India
Hi
1800mfd/450vdc Mallory make screw terminal this cap. available in one source in india
samking
Old 22nd November 2009, 05:47 PM   #6
Thanks, guys, for the information. It's extremely helpful. Just what I was need to move my project to the next step.
For the 1800uF caps, I think I will go with the Nippon Chemi-Cons first, for their affordability. Maybe upgrade to the Panasonics later to see if they sound better.
Thanks!
KT
hifi large capacity;nichicon KZ uhcmos Swap Meet 71 20th January 2011 10:57 PM
WTB: 35V snap-in caps large capacity len_scanlan Swap Meet 0 3rd March 2009 12:27 AM
High Voltage Electrolytic Caps Bengali Parts 4 19th October 2007 08:45 AM
Large capacitors low and high voltage rkc7 Swap Meet 0 24th March 2006 03:17 PM
High Voltage Power Supply Caps Bryan Tubes / Valves 14 4th September 2005 08:31 AM
Page generated in 0.09267 seconds (74.63% PHP - 25.37% MySQL) with 10 queries
