diyAudio Sponsor
Old 24th November 2009, 02:08 AM   #11
SY's Avatar
It's in Variac's hands and will be up shortly. (hint: D3a)
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 29th November 2009, 11:20 PM   #12
nullspace's Avatar
So, I've been looking at the D3A, triode-connected and loaded with a CCS. How does 150Vpk, -1.5Vgk, and 20mA sound in terms of an operating point?
John
Old 30th November 2009, 01:00 AM   #13
nullspace's Avatar
Ugh. Such poor typing... I meant 160Vpk, -1.5Vgk, 20mA.
John
Old 30th November 2009, 01:03 AM   #14
kevinkr's Avatar
John
If you mean Vp of 150V and -1.5Vgk with ~20mA this sounds like a reasonable choice for the type.
I'm running mine a little colder with -1.2Vgk (diode bias), 15mA and 100V on the plates with very good results. Note that variations in plate current can be rather large with very small changes in Vgk as well as due to the gm spread from sample to sample so if setting a specific operating point is important to you a CCS removes the uncertainty - in practice I use tube based gyrators as loads in my design and while it is not constant current, the load impedance is high compared to the rp so the gain is very consistent over a wide range of device transconductances.
www.kta-hifi.net
Old 30th November 2009, 01:08 AM   #15
kevinkr's Avatar
John
While I understand what you mean the voltage from plate to cathode, generally Vpk is taken to mean volts peak. I don't recommend you use this term as it is confusing unless you define it clearly in your post. (The problem is the lack of subscripts that would make it clearer.)
www.kta-hifi.net
Old 30th November 2009, 02:44 AM   #16
nullspace's Avatar
Thanks for the feedback, Kevin; I appreciate it.
I'll reconsider my use of Vpk; thanks for the perspective.
John
Old 1st December 2009, 08:47 PM   #17
nullspace's Avatar
More thoughts...
If I'm going to go with a triode-connected D3A in the first-stage, should I go with another D3A in the second stage or should I pick something else based on my target voltage gain? Given the D3A's mu of ~75, I only need a mu of ~22 for the second stage to get me to 44dB, which is about what I was looking for. How about an active-loaded ECC99? Might that work well as the second stage?
With the D3A, g2 is tied to the anode and g3/shield is tied to the cathode, is this correct? And, I'm assuming that all three grids will need stoppers, is that right?
Thanks for the help.
John
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Copland CTA-402 Phono Section Comments Algar_emi Tubes / Valves 52 30th April 2008 06:12 AM
A CFB BJT preamp - any comments? PMA Solid State 19 24th June 2006 06:18 AM
Comments about the quality of Pass Labs' products peranders Pass Labs 36 26th December 2002 05:18 AM
Comments on a preamp design mpeg7 Tubes / Valves 9 17th September 2002 10:46 AM
Page generated in 0.10422 seconds (72.30% PHP - 27.70% MySQL) with 10 queries
