diyAudio Sponsor
Old 21st November 2009, 04:59 PM   #11
TerryO is offline TerryO  United States
TerryO's Avatar
Originally Posted by Richard Ellis View Post
Some more to consider...One-Electron, and SP Wound components Ltd.
I had a good talk with the fellows at SP wound, very helpful!
Jack at Electraprint is another good choice...more than willing to chat with.
________________________________________________Ri ck..........
Rick,
I don't know anything about One-Electron or SP Wound, but I forgot about Electraprint, which a late friend (who was an absolute whiz with tube amp design) recommended highly.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 22nd November 2009, 04:14 AM   #12
BudP is offline BudP  United States
BudP's Avatar
If you are just having fun, experimenting and such, don't spend your money on top performance level OPT's. Edcore, Hammond and James, if you can find an inexpensive set, would be my first choices, and none of them have any thing to apologize for, sonically or build wise.
Once you have an amp figured out and know what you need, then come and talk to those of us hungry to slip many dollars out of your wallet. As an example, a 10 watt pair of level one OPT's, custom designed for your end needs, will be about $80 each from me. They are actually worth the money, as are the products from Magnequest, Electraprint, Lundahl, Slagle and Plitron. But, not until you have your circuit stable and have worked on passive parts quality levels. Then the transformer, which is 90% of what is wrong with a tube amp and 70% of what is right, will actually be a worthwhile upgrade.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 22nd November 2009, 06:39 AM   #13
Cycline3's Avatar
ive used the 60w & 100w edcors -- the high quality ones not the guitar open frame ones -- and they are exceptional. better than any scott or eico old school transformer i have and 99% good enough for most audiophiles. if you dont get them sounding good, it's your design, not the transformers. considering the price, nothing comes close. why pay more?
My site:
http://www.seanrose.com
Old 25th November 2009, 05:43 PM   #14
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Thanks all. It looks like the Edcors are easiest to get and I may try a pair of them.
I'm considering the CXPP10-MS-5K but I need a 8-12K transformer so I could just put my 8 ohm speakers on the 4 ohm tap and use it. Not optimum since the 16 ohm tap is probably wound with finer wire than the 8 and 4 ohm taps, but it should work fine.
On the other hand, the CXPP25-MS-8K could be used and should provide less distortion with a pair of 6P1Ps. In addition, I could use this transformer for a Parallel PP amp with four 6P1Ps by moving to the 16 ohm tap. Again the wire size issue.
The only source for James I've found is OCTAVE out of Malaysia.
Old 25th November 2009, 06:31 PM   #15
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
For push-pull, I want to try the Antek toroidal OPT's
Antek - Your reliable source of transformers, power supplies, and more. .
Old 25th November 2009, 07:46 PM   #16
Just bought a pair of CXPP25-6-7.6K Edcors today for my new EL84 push-pull design.
(p.s. it uses an LL1540 transformer for the phase splitter, so I also bought some Edcor PC10K/10K to compare!)
UGH! Three week lead time!
Old 25th November 2009, 08:55 PM   #17
BudP's Avatar
In the transformer business, three week lead time is incredibly fast. I never quote less than eight.
Bud
Old 3rd December 2009, 03:41 AM   #18
Wink Re: Transformers to try.
Keeping the safety of the device in mind, I think it is wise to go with a transformer supporting a higher capacity than the required 20 to 30 watts. LiteFuze 50 Watt Step Down Travel Voltage Converters available from LiteFuzeVoltageConverters.com will be just right for your model.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
FS: Transformers alexcd Swap Meet 0 19th November 2008 09:34 PM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 12:38 PM
Where to buy transformers SupraGuy Parts 6 9th September 2004 04:06 AM
Can i use one of these transformers? Matttcattt Parts 5 18th September 2003 05:12 PM
Page generated in 0.10957 seconds (80.60% PHP - 19.40% MySQL) with 10 queries
