diyAudio Sponsor
Old 19th November 2009, 04:02 PM   #11
m6tt is offline m6tt  United States
Don't forget 6J6A and its many computer variants...cheap enough to select for audio quality, Rp 7k, mu 38. Shared cathode though, makes a good LTP
Old 19th November 2009, 11:22 PM   #12
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
It will eventually go inside the guitar.
Lol. First time a tube gets inside a guitar's body. But where? Booster or buffer? Microphonics possiby a problem? I have to see that.
Old 20th November 2009, 05:08 AM   #13
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Pay attention to the circuit if you use 6J6, he's prone to break out into oscillation if you look at it sideways.
Old 20th November 2009, 09:59 PM   #14
Cassiel's Avatar
By the way Colt, the 6j6 russian variant is kinda crappy. Sounds ok but my God i thought i was watching a submarine movie, you know...ping...ping...ping.
Microphonic!
Old 20th November 2009, 11:31 PM   #15
defect9 is offline defect9  Ireland
defect9's Avatar
depending on the intended sound, the microphonics might make it sound amazing
Old 21st November 2009, 01:58 AM   #16
Cassiel's Avatar
He should open a new thread telling more about it.
Maybe he will do in his webpage.
Old 21st November 2009, 08:07 AM   #17
...so I guess that would be the first tube pickup.
Martin
Old 21st November 2009, 10:14 AM   #18
defect9's Avatar
you know if you want a nice microphonic tube to try it with, the 6418 submini is a nigh-perfect candidate. those things ring like church bells in a hurricane (and they're easily dampened with small rubber grommets if you feel the effect detracts from the sound)
Old 21st November 2009, 05:43 PM   #19
kevinkr's Avatar
Martin
Nope... Check this out, a tube used as a transducer - in this case a phono pickup.
Vacuum tube phono cartridge
This device was used in all sorts of other applications as well..
www.kta-hifi.net
question about twin triode tubes Nihilist Tubes / Valves 2 19th February 2009 04:39 AM
Best/favorite CF NOS noval twin triode? leadbelly Tubes / Valves 34 19th April 2008 04:37 PM
Physically small rectifier tube with 5V heaters dsavitsk Tubes / Valves 7 14th June 2006 02:47 AM
Any subs for 6N1 & 6N2 twin triode valves? rcavictim Tubes / Valves 39 20th April 2005 02:19 PM
mmm.... zero-bias class B twin triode amp Circlotron Tubes / Valves 6 5th March 2003 12:49 AM
Page generated in 0.12396 seconds (74.76% PHP - 25.24% MySQL) with 10 queries
