| diyAudio Sponsor | ||
I have a quick noob question about a PT I have. It's secondaries are labeled like this:
250V/100mA - 0V - 250V/100mA I'm not certain what this means the current rating is. I'm guessing another way to show this is 500VCT/200mA, correct? Or is it 500VCT / 100mA ? TIA! |
#2 |
500VCT @ 100 mA. DC output capacity will be about 100 mA as well. DC current could be more with choke input, but voltage would be too low for most applications.
#3 |
Thank you sir!
#4 |
On the same subject, I never got this really clear.
If I for example have a 500VCT @100mA TX what can I expect it to handle if used for bridge rectification instead of the (I suppose) expected full wave rectification. Can I actually pull 100mA @ 500V? /Olof
I'm not allowed to do magic, union rules... |
#5 |
No, you can't get 100 mA since you have to supply capacitor ripple current as well as dc current - 60-70 mA would be more like it. With choke input you could get 90 mA or so. Duncan Amps PSU designer can give a good idea of the RMS transformer current for a given DC current.
#6 | |
Yes I am aware of this, it was late and I did not express myself very clear. I refered to actual AC current to be drawn from the secondary. What I really wonder is; if a TX is spec'd at 500VCT@100mA, is this for use in a full wave circuit where you actually can draw approx 60-70 mA at 350VDC? Or can it be used in a bridge circuit to supply 60-70mA @ 700VDC? It is quite a difference. /Olof
#7 |
About 100 mA in a full-wave center-tap circuit, maybe 130 mA with choke input. About 60-70 mA at 700V in full-wave bridge. About 90 mA at 500V with FWB and choke input filter. Any of these result in about 100 mA RMS AC current in the transformer secondary.
| transformer question | abiedoodles | Parts | 3 | 10th February 2008 12:35 PM |
| Another transformer question | kneadle | Chip Amps | 12 | 13th May 2006 09:08 PM |
| Transformer and GC question | 41 | Chip Amps | 7 | 28th July 2004 12:46 AM |
| Transformer Question | PassFan | Tubes / Valves | 24 | 12th November 2003 07:12 PM |
| SOZ Transformer Question | gnomus | Pass Labs | 1 | 9th January 2002 07:21 PM |
| Page generated in 0.08899 seconds (79.81% PHP - 20.19% MySQL) with 10 queries |
