diyAudio Sponsor
Old 14th June 2010, 07:31 PM   #381
OneyedK is offline OneyedK  Belgium
Originally Posted by Wavebourn View Post
Please explain why matching pair of tubes is so critical, why someone would seriously consider matching all of them.
This amp consists of 3 stages. All of them determine the distortion characteristics of the amp.
A (big) difference between the distortion produced by each channel, destroys or at least distorts the imaging.
2 out of 3 stages are determined by the driver/phasesplitter section around the 6N1.
The first stage already has a rather low anode-cathode voltage, so even smaller differences
between tubes will create a different opearing point. Different operating point means
different distortion spectrum.
That's the reason why I want those 6N1P's (or equivalents) to be matched.
In this case, they don't have to be internally balanced, but matched between tubes.
To a lesser extent, the same thing goes for power tubes.
But a matched quad is not more expensive than two matched pairs...
So why would I buy two pairs?
btw, I found nothing bad on the stock chinese 6P15's, they were properly matched (or it was just my lucky day).
The chinese 6N1P's were far worse! (badly constructed and totally different from each other) Replaced them with Siemens E88CC - yes, matched pair.
Old 14th June 2010, 08:18 PM   #382
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The keyword is (big)
How big is the difference if output pairs are not matched? Is it audible at all?
This is the question.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 14th June 2010, 09:25 PM   #383
Thing is, I don't know what the maximum allowed mismatch between channels is.
(maybe it's bigger than I assume now)
But if you bias one channel slightly hot and on slightly cold (changing cathode resistors), the effect is clearly audible.
- male voices crawl to the hot channel, female voices to the cold -
Old 14th June 2010, 09:29 PM   #384
Wavebourn's Avatar
How deep is feedback in the amp?
Old 14th June 2010, 10:35 PM   #385
If I'm correct, open loop gain is around 21, closed loop gain around 8.
That's -8.4dB.
Why the question?
Old 14th June 2010, 11:06 PM   #386
Wavebourn's Avatar
That's -8.4dB.
Why the question?
How big will be the difference in gain if tube pairs are unmatched when this feedback is applied?
Old 15th June 2010, 07:29 AM   #387
Wow, I overlooked the 200V limit of g2.
This means that the Suppo Golden Voice, supplied with Chinese 6P15 tubes is actually wired in "self destruct" mode. (original schematic)
Lucky for Joe we all voided warranty
Only peepz with JJ EL84's are safe.
I pretty much do NOT understand anything on page 31 tubesteve's post (#308) and oneyedk's post(#310).
oneyedk, what all this means? (tubesteve's and your post). I don't understand any technical discussions. Can you do an outline in simple understandable language for people like me? Is Suppo golden voice with 6P15 tubes bound to die after short service duration? So does this mean only safe tube choice is the JJ EL84's?
Old 15th June 2010, 10:44 AM   #388
Euhm... There will be no difference in gain...
Problem is not the difference in gain, but the difference in "colour" between channels.
On paper, the only safe choice is JJ EL84.
(JJ EL84 is the best current production EL84 on the market, available at a fair price)
In practice, the stock 6P15's of the suppo seem to survive the theoretical abuse. Mine are still triode strapped without lowering g2 voltage.
If they would die a little early, it's not a big deal, they don't cost an arm or a leg (if you stay with 6P15-EV's or JJ EL84)
Old 15th June 2010, 05:21 PM   #389
The impression I got was that using 6P15 meant shorter life for the amplifier itself. That's really not the case right?
Old 16th June 2010, 08:31 PM   #390
Difficult to answer that question...
Nobody knows how much these particular 6P15's can take, mine show no signs of decay after about 6 months of use (or abuse, if you like).
The people at Suppo are very helpful and friendly, so if you run the amp with stock tubes and it fails after a short while, I'm sure they will help.
On the other hand, this amp is fairly simple, so if a failing tube would take out some components, they are replaceable.
we don't choose tube amps for their reliability, nor do we read and post on DIYaudio to leave amps as they were
cheap Chinese amp modules on ebay . Anyone know what they are ? jives11 Chip Amps 36 28th November 2008 04:35 PM
FS/T: Lite Audio Chinese audio preamp PCBs CaliforniaBob Swap Meet 0 26th July 2007 09:36 PM
Cheap and Chinese KT88 SE amp andrew_whitham Tubes / Valves 46 19th May 2007 11:05 AM
WTT Amp6 Int. Amp for cheap chinese tube Int. Amp mrdon Swap Meet 2 28th July 2006 11:03 AM
Cheap SE EL84 DocLorren Tubes / Valves 8 13th September 2005 03:18 PM
Page generated in 0.24603 seconds (41.04% PHP - 58.96% MySQL) with 11 queries
