| diyAudio Sponsor | ||
I have a power transformer with a 22 volt bias winding built for 6L6GC use. Is there any reason I can't use a voltage doubler circuit to get the bias up higher as need for EL34s?
#2 |
You can use voltage doubler, no problem.
#3 |
no reason at all as long as you aren't going deep Class B or worse where the ability to deliver grid current will be an issue...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#4 |
Of course, usually for the same operating point EL34 needs less value bias voltage than 6L6 types.
#5 |
Great.
I have this mono 6L6 amp out of an organ that's been setting around for a while. It's got some good really good iron and a big 19.5:1 PP transformer. I suppose it would make a good harp amp or perhaps a sub-woofer amp; I really don't need another mono hi-fi amp. It's got a really spacious chassis and several unused octal sockets (it used to have a second channel to power a field coil speaker). I'm looking for an odd project and none of those ideas work for me. So, I was thinking of setting it up as a hi fi amp, but set it up so that it can play a wide variety of tube types. Basically, anything that can handle the 3K OT primarys that result from an 8 ohm load. Just to see if I can. Crazy but fun idea. Should be able to build it from the parts pile. Last edited by Captn Dave; 15th November 2009 at 02:05 PM. |
| F5 bias question | richD | Pass Labs | 8 | 21st August 2009 04:29 PM |
| Bias Question | Rob11966 | Tubes / Valves | 5 | 13th April 2009 12:14 PM |
| Nifty little (cheap ) transformer for bias supply | flacoman | Tubes / Valves | 3 | 22nd October 2008 12:42 AM |
| Bias pot question | Original Burnedfingers | Tubes / Valves | 1 | 1st January 2006 02:49 PM |
| Page generated in 0.07899 seconds (69.44% PHP - 30.56% MySQL) with 10 queries |
