| diyAudio Sponsor | ||
Much as the binkum in the Wikipedia "valve sound" article grates due to its poor/selective/non-existent quoting of references, the regularly touted pleasing nature of second harmonic distortion is interesting.
Once one moves away from a global loop feedback circuit to a design with zero feedback then the possibility to dial in second harmonic distortion deliberately raises its head. For instance, in the PP el84 amp I'm working on, simply by increasing the negative bias voltage on the input tube (6CG7) from 5v to around 10v I slide along the load line from a point where the lines are pretty evenly spaced to a point where there's a decent wad of 2nd harmonic being produced. So, while in theory accuracy is what we strive for, do any of you deliberately engineer second harmonic into your designs? (I'm not saying that I intend to, merely curious to see if anyone does) |
#2 |
Yes and no. This is one of those deals where lots of people do it but either don't know that's why they like it better or won't admit it.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
I've been playing around with this for a while. I've found that dialing in a little extra 2nd harmonic can make 'dry' speakers, like many metal coned drivers, sound more listenable.
An interesting arrangement is to use starved filaments and at the same time using 0V bias. Here is Steve Benchs work... DHT with starved filaments. Using the 01A as a driver with fil of 3.2v, anode 60v and bias 0v is a surprisingly enjoyable listen, albeit high distortion. The imaging is spectacular, likely because of the directly grounded cathode and no cap in the signal path on the grid or cathode of the tube. |
#4 | |
As for the last part, yes most guys would rather admit to have problems satisfying their woman , than that they actually like distortion. However, in the tests I have performed, it was evident that many actually prefers some distortion, over say 0.0002% THD. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#5 |
there are other things.............clarity of the audio image and speed of followers, good local feed back etc. so sometimes there must be a pay off between them to get what you like best from your speaker drives.
#6 | |
#7 |
Banned
#8 |
IMO, it's a matter of distortion spectrum. That's why I strongly advocate the use of 12AT7s in PP designs. The NET HD spectrum is an ear pleasing "waterfall" of 2nd > 3rd > 4th ... The 12AT7's bias towards 2nd order products meshes very well with the internal even order product cancellation inherent to PP "finals".
IM distortion is an altogether different matter. As IM products are unrelated to the desired signal, they are EXTREMELY irritating. Therefore, getting the IM distortion of a circuit as close to zero as can be is a good thing. To a degree, music masks HD and underscores IMD.
Eli D. |
#9 | |
Banned
#10 |
R.I.P.
Take any "tube output" Chinese made CD/SACD player. Put in a test disc and measure the audio distortion before (very low) and after the tube - VERY high, and mostly 2nd h!
Yet some people just love the sound of these sonic attrocities. But the worst I have ever seen/heard is a German CD player based on a Playstation mechanism, with a EL34 as an output amp, with something like a 100k anode load R. Over 25% 2nd harmonic! And when I corrected it - the owner demanded it be put back as it was! Chocolate sauce is chocolate sauce...and some peole can't get enough of it! Regards, Allen |
| deliberately unmatching output tubes | porl | Tubes / Valves | 17 | 15th January 2010 11:28 PM |
| 90 % completed - not dial-up friendly | Madmike2 | Car Audio | 11 | 20th October 2007 04:29 AM |
| Need to make a new dial scale | Original Burnedfingers | Everything Else | 7 | 30th September 2006 04:18 AM |
| for Sale: Doepfer Pocket Dial SE | neodjandre | Swap Meet | 1 | 21st March 2004 11:32 PM |
| jog dial | Bernhard | Digital Source | 0 | 27th January 2004 09:52 PM |
| Page generated in 0.12326 seconds (80.30% PHP - 19.70% MySQL) with 10 queries |
