diyAudio Sponsor
Old 13th November 2009, 05:14 PM   #1
bob56 is offline bob56  United States
Default El34-kt88
Is it possible to convert the Dynaco Stereo 70 to use KT88s? What is the easiest way? Would the stock transformers be adequate?
Old 13th November 2009, 05:41 PM   #2
Ty_Bower's Avatar
The output transformers will likely be just fine. The power transformer is barely adequate for four EL34, much less a quad of KT88. Forget about trying to use a single 5AR4 for power supply rectification.
Other than those minor issues, the conversion is straightforward. Bob Latino sells such an amp commercially. Perhaps you could look at his design and try to clone it.
http://www.tubes4hifi.com/bob
EL34, KT88, High Voltage?, VTL.. kegger Tubes / Valves 20 4th July 2009 01:41 PM
EL34 and KT88??? 6550? forsakenrider Tubes / Valves 4 18th February 2008 03:10 PM
Autobias for 6L6/EL34/KT88 SWMoore Tubes / Valves 10 2nd April 2003 07:26 AM
Page generated in 0.09220 seconds (62.33% PHP - 37.67% MySQL) with 10 queries
