| diyAudio Sponsor | ||
A local guy picked up a pre which he now has issues with an brought it to me.
It uses one of those DIY-GENE regulated supply boards that take that Chinese 6Z4, a 12B4 and a 12AT7 in it's supply. 2 different 6Z4 rectifiers exhibit the usual things when there dying/dead with a nice fireworks in the bottle, have 1 more to try, but no way to test the things on any of my testers (that I know of yet) before trying the last one he has I'd looked over the circuit, it has a 180uf cap hanging right off the rectifier so it's a cap input supply with a LARGE cap on that input. Now I wouldn't go anywhere near that amount even on a 5AR4 let alone a 6X4 size rectifier like this 6Z4, so am I to assume this thing is just eating rectifiers with that 180uf cap hanging there or am I missing something? I've found a few different schematics for this same supply board and they all pretty much use in that 200uf range on the cap input supply. From everything I've done in the past tells me this is a flawed arrangement, no? Now I could modify the circuit and put say a 100ohm resistor on that input or go and change the first cap to a small poly then use a new rectifier and I should be fine but I'm just finding it at least a touch difficult to believe how this was done.. (following that first stage is an RC stage of 500ohm and another 180uf cap) Attached is the same basic supply.. any thoughts? |
#2 |
It is clearly a faulty design. Probably originally intended for use with a solid state rectifier and later some moron tweaked it for better sound and it didn't blow straight away
#3 |
Eeeeek!
![]() I can see several things wrong with that straight away too. Even if the rectifier survives with that much capacitance, how on earth does the regulator do its job with C12 so high and C10 so small? Not to mention R22 being a good 1/10 the size it should be and the circuit would likely be more stable without C19. Cheers! |
#4 |
Thanks guy's for the reassurance.. Now to decide how I'm going to proceed..
#5 | |
The input cap needs to be much smaller, presumably one might get away with the huge input cap if the winding resistance of the high voltage secondary was quite high. As Geek points out:
www.kta-hifi.net Last edited by kevinkr; 13th November 2009 at 04:53 PM. |
#6 |
Thanks for the input guy's.
I don't have a lot of regulated supply experience, especially one like this. (comments are much welcome) Yah power tranny resistance is up there, 270ohms from each leg to center tap, but I still wouldn't want that much capacitance on these tiny rectifiers. I'll probably spice Sim this thing and learn a bit more about it, now in 1 place it was said to remove C19, in another replace it with a film cap 10uf or less? If it were mine, yah I'd be substituting R19 with choke, not sure I follow the part about R22 and where to power it from/hook it back in though. Leaving C10 out just means removing it an doing nothing else to the circuit? |
#7 |
#8 |
Kegger,
Did you ever sort out that power supply, and if so can you post your changes. Bonanza |
| Regulated B+ supplies (using tubes) | jarthel | Tubes / Valves | 13 | 30th July 2006 09:15 AM |
| question about regulated supplies. | martyh | Chip Amps | 0 | 11th January 2005 01:52 PM |
| Regulated Power supplies | Ryder | Solid State | 44 | 21st April 2004 05:15 PM |
| FS: (2) 28 VDC 11 AMP regulated power supplies. | FEThead | Swap Meet | 1 | 2nd May 2002 04:18 PM |
| Regulated power supplies | Jason Hubbard | Solid State | 20 | 10th September 2001 08:33 PM |
| Page generated in 0.11643 seconds (71.12% PHP - 28.88% MySQL) with 11 queries |
