| diyAudio Sponsor | ||
Hello all,
I'm looking for a input/phase splitting stage for a PP amplifier. I've got both halves of an ECC81 / 12AT7 available per channel. The complete stage does not have to have any gain, just a phase-split of reasonable-to-good hifi standard. The output(s) of the splitter will go through caps to both halves of an ECC83 to drive EL34's in their turn. I've got a B+ of 300V Has anybody got a schematic which I could use ? Gracias, Empee |
#2 |
R.I.P.
ECC83 to drive EL34's in their turn.<< Why would you put a low power, low current ECC83 after a much higher current higher power ECC81? Let the ECC81 drive the EL34's, and put any ECC83 gain stages BEFORE the splitter, not after. Regards, Allen |
#3 | |
Here is an example: 6F6 Amps |
#5 | |
that would be because I'd like to try two SE amps which I already build as one mono PP. So the ECC83 is already taken I got one PP output transformer so I thought I'd give it a try.... Thanks ! Empee |
| phase splitter with Tr ? | sam8888ysl | Tubes / Valves | 9 | 22nd October 2008 11:28 AM |
| Looking for 12AT7/ECC81 phonostage schematic | alexg | Tubes / Valves | 1 | 21st August 2008 03:13 PM |
| Ecc81 12at7 | 316a | Swap Meet | 0 | 30th May 2008 11:51 AM |
| Cascode with ECC81(12AT7)=>Morgan Jones | AudioAngel | Tubes / Valves | 48 | 28th November 2006 03:27 PM |
| Page generated in 2.22565 seconds (5.15% PHP - 94.85% MySQL) with 11 queries |
