help battery biasing 6dj8's
Old 22nd May 2003, 11:53 AM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default help battery biasing 6dj8's
I've got some 6dj8 tubes in a common-cathode configuration with a cap bypassed cathode resistor. I'd like to try battery biasing, but what would be the optimal voltage of the battery used? Also, if I use a battery with whatever voltage you guys sugest, what anode resistor should I use with a 180V B+? Thanks, but I'm still a little unsure when it comes to tubes, but I'm progressing...
Old 22nd May 2003, 02:22 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
2.5V to 3V is generally a nice voltage. A 3V lithium is actually closer to 3.6V. A charging pair of > 80mA/hr NiMH in series in the cathode will give about 3V. Alternatively, you could use grid bias with a pair of AA alkaline batteries in series with your grid leak resistor. Try 18k as your anode load, and it should draw about 4mA with 3V bias.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 22nd May 2003, 04:49 PM   #3
JoeBob's Avatar
I hear many people warn against starving them of current, so I'll try your sugestion and see how it works, 4mA counds plenty. Thanks.
Old 23rd May 2003, 05:30 AM   #4
NickC is offline NickC
can i run battery biasing with a constant current as a plate resistor for a 6992?
Old 23rd May 2003, 09:33 AM   #5
EC8010's Avatar
That's even better. The battery voltage will effectively set the anode voltage, so you can just choose it to maximise output swing.
Old 23rd May 2003, 12:42 PM   #6
JoeBob's Avatar
Want to explain to me the AA grid bias? As I said, I'm a noobe to tubes... Also, what would I go about doing if I were to change the B+? I'd only change the anode resistor with proportion to the change in B+, right? Ah, so many questions...
Old 4th June 2003, 04:25 AM   #7
have bought some ni-cd for used with battery biasing 6922. I am now charging them to full capacity. Once i install them can i leave them in the circuit continuesly connected? Or do i need a switch to disconnect them when i am not using the amp? As i read somewhere that what the amp is running the batteries get charge rite? Plus i am running the 6922 at 9ma hence the batteries should get charge by around this value rite? Your input on having a switch or without it please.
Old 4th June 2003, 11:19 AM   #8
EC8010's Avatar
JoeBob,
you need a set of anode characteristics for your valve. This is a set of graphs that shows anode current against anode voltage for differing values of grid-cathode bias. An excellent source for these is:
http://home.planet.nl/~frank.philipse/frank/frank.html
Once you have these curves, you choose your HT or B+ voltage, and mark this on the voltage axis. Then, having chosen the resistance of your anode load, you divide this into the HT voltage to find the maximum current that could flow, and mark this current on the current axis. You now draw a straight line between your two marked points. This is your loadline, and shows how the anode voltage can vary with your chosen HT voltage and anode load. The operating point along this loadline is determined by the grid-cathode bias voltage you choose. This is necessarily rather abbreviated, but there are lots of currently available books that go into more detail - have a look at the component distributors.
NickC,
if you have your NiCd permanently connected in the cathode circuit with its positive terminal connected to the cathode, when you apply HT, current will flow into the NiCd to charge it. If the battery is already charged, this current heats the battery. Trickle chargers charge at C/10 (C is the battery capacity in Ahrs) because overcharging at this rate does not cause damage. Thus, a typical 0.5Ahr AA NiCd would be trickle charged at 50mA. Your battery is going to be rather warmer (it's near a valve), so I would recommend that you choose a battery with a rating of >20 your anode current = 20 x 0.009 = 0.18Ahr. An AA NiCd would be fine. Lastly, if you are going to buy new, buy NiMH rather than NiCd. One day, it will have to be disposed of, and cadmium is nasty stuff. NiMH not only offers greater capacity, but it's more environmentally friendly.
Old 4th June 2003, 12:38 PM   #9
ec8010 thanks for the help. However i bought a 600 mah ni-cd aready. I would like to say also thanks for the enviromental tip but it came abit late.
Old 4th June 2003, 12:41 PM   #10
EC8010's Avatar
You're welcome. Your 600mA/hr part will be just fine.
help battery biasing 6dj8'sHide this!Advertise here!
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 02:18 PM
6DJ8 biasing question jcc147 Tubes / Valves 10 12th February 2009 07:46 PM
6DJ8 or 12AT7 hags Tubes / Valves 4 22nd February 2007 12:16 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 04:45 AM
