information needed...Antique Sound USA PA-3 preamp - Page 2 - diyAudio
Old 30th May 2003, 11:47 AM   #11
Frank
I can't find a listing for them. I assume they are out of business. I can't even find a review of the Antique Sound USA PA-3 preamp.
I need a transformer of some type so I can fire this thing up.
Joe
Old 30th May 2003, 09:21 PM   #12
diyAudio Senior Member
fdegrove's Avatar
Hi Joe,
Have you looked at the Hammond site?
They may have something usefull, probably not on a single xformer but still better than nothing at all.
Frank
Old 30th May 2003, 11:59 PM   #13
Frank
I FOUND A TRANSFORMER WITH THE FOLLOWING SPECIFICATIONS. 6.3 volts/2A 100volts/30ma and 250volts/50ma
Does this sound ample to run 3 5814A's? The listing of tubes says: 12AX7, 12AU7, 6sn7 X 4
Does this sound like its ample in size to you?
thanks
Joe
Old 31st May 2003, 12:09 AM   #14
fdegrove's Avatar
The entire tubelisting looks odd to me...
3 x5814 which are just 12Au7S + what? a 12AX7, yet another
12AU7 and than 4 6SN7s?
For a linestage this is rather hard to believe unless some (say 3/4) of the valves are used as regulators...which I somehow feel is quite unlikely...
Back to the drawing board I'd say,
Frank
Old 31st May 2003, 12:15 AM   #15
Frank
Sorry to confuse you. The information on the transformer states that it can run 12AX7,12AU7, and 6sn7 times four. I would assume it means it has enough guts to run 4 12AX7's or 4 12AU7's or 4 6sn7's.
The preamp I purchased has only 3 5814A's in it so I would assume the transformer should be ample to run it.
Joe
Old 31st May 2003, 12:19 AM   #16
fdegrove's Avatar
Default Ah...
Yep, should do...
Boy, did you have me worried there...
Kidding, Joe...
Frank
Old 9th June 2003, 12:41 AM   #17
I ran across another preamp with the same schematic as the Antique Sound USA. I will try to attach a schematic.
Antique Sound Lab Aq1003 cfamily Tubes / Valves 23 15th September 2015 06:02 AM
FS : Antique Sound Labs AQ-1003 PCB for DIY (INTEGRATED AMP EL34 PP) ANALOG GUY Swap Meet 7 21st April 2012 12:23 AM
For Sale: Antique Sound Lab SE Class A Gaucho Swap Meet 0 15th March 2005 03:30 AM
Antique Sound Lab MG-SPM25 Output Transformers PTSOUNDLAB Tubes / Valves 0 3rd April 2004 12:49 PM
Antique Sound Lab (ASL) Wave AV-8 tube amps w/ Auricaps and more Saurav Swap Meet 3 20th August 2003 05:32 PM
Copyright 1999-2017 diyAudio
