| diyAudio Sponsor | ||
It's been a little while since there was such a discussion here so I'd like to start one. Simply stated, everyone has their own preferences. What sounds good to one person may not sound good to another so where possible, we must use objective criteria also.
I propose we all pitch in and discuss our favorite ( to date ) 6SN7 grading it on the objective and subjective qualities of linearity, frequency response, clarity, low distortion, transparency and just listening pleasure. I have listened to a few 6SN7s, the various Sylvanias, the RCAs, Raytheons, etc. but I just got a pair of Russian metal base rounded hole plate "OTK" stamped MELZ manufactured 6N8S specimens. ![]() Unfortunately I have only the subjective grading methods but wow! The clarity! The additional instruments that can be heard! The depth! The incredible frequency response! It was like the dead waking to a beautiful mountain sunrise with gentle breezes, distant birds and a huge thundering waterfall. The formerly dead would be awestruck by this aural pleasure as I was by these tubes. They have my vote for the Ultimate 6SN7. |
#2 |
alternatively, they have a spec that just happens to hit the frequencies that align with your pattern of hearing loss as long as they are installed in your amp and its tied to your source and speakers, in your listening room.
Glad you found some that work so well for you though.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
CV1988. Quiet, clean. Problem is, it's tall so won't fit under the lid in many builds.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
The ultimate 6SN7 for me wasn't a 6SN7 at all. I replaced the 6SN7s in my Supratek Chenin preamp with CCS loaded 2C22 single triodes, biased to 3.4V using (4) Cree SiC Schottky Diodes on the cathode. To say they were MUCH MUCH better is an understatement. The 2C22 is roughly equivalent to 1/2 of a 6SN7, but the anode and grid are taken out via top caps.
Bass is clearer and more defined, mids are to die for, treble is sparkling without being grating. Using the CCS I am able to replace both sections of the 6SN7 with a single 2C22 and still have plenty of gain. Picture #1 is of the cascoded IXYS 10M45S CCS, #2 is of the (4) SiC diodes for bias, #3 is of the Preamp with the 2C22 tubes installed. I used a socket adapter initially due to the different tube pinouts, but I have since made the install permanent by punching holes in the top plate for the wires to pass through, so the adapters shown in photo #3 are no longer there. |
#5 |
7N7 is the best 6SN7 kind that I like the best.
Johnny |
#6 | |
Surely you must realize (and your own post illustrates the futility) that "objective" somehow fails to apply at this forum? Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#7 | |
![]() Seriously though for good karmic vibes I find the Sylvania 6SN7/GA/GB pretty hard to beat at least into late 1970s era production. They're well balanced spectrally speaking, clean and detailed. They're still among the more reasonably priced brands of this type - personally I prefer them to the several pairs of vintage Tungsols I own. I would rank the GE and Raytheon versions as poor sounding in comparison to either the Sylvania or Tungsol. Brimar made some nice ones too, tend to be a bit lusher and more romantic sounding, were (are) favored by some for this reason. My comments are of course very subjective, on the linearity front I have not seen huge differences between brands and vintages except in a few extreme cases. Distortion spectra does seem to be influenced by geometry. I guess that may be why I like the Sylvanias so much. All of my designs are 0 fdbk and I have used 6SN7 in line stages and the driver stages of power amplifiers. I have heard a few amps and pre-amps designed by others that used the 6SN7.. I would consider my exposure to other hardware using them pretty limited. Results are likely to be different depending on design constraints, listening preferences, and other system components.
www.kta-hifi.net |
#8 | |
There are all sorts of people participating here, some, like me, have engineering backgrounds and try hard to correlate what we measure with what we believe we are hearing. I can't always make the correlation, but I strive for good electrical performance within the context of what (I think) is reasonable for the technology I am using. Others have neither the resources, experience or in some cases the inclination to do the deep dive required. Designing is all about the art of compromise, understanding how what you are doing affects other circuit parameters that may not necessarily improve when you make a change that improves what you are currently focused on. Anticipating unexpected results, and knowing or figuring out how to deal with them is key. Sometimes listening provides irrefutable evidence that something is still not quite right, and you head back to the bench to find out why. (I have had a very recent experience with a phono pre I designed - no measurements I could perform directly told me what was wrong with it, listening indicated clearly that there was a problem. The issue was ultimately traced to the electrolytic cathode bypass caps in the first stage, but no standard audio (static) bench measurement ever showed there was a problem - changing to diode bias fixed the issue. Non blind A/B comparison between two pre-amps confirmed the problem existed, and also that it was fixed.) I'm not terribly effronted by most things I read here whether or not I agree with them as long as they are not couched in a direct personal attack, which IMO is inexcusable. IMHO: Objectively speaking there is no reason for anyone to use tubes, but I do, and for reasons I think are technically sound, but others may find specious. (Nature of their distortion spectrum, linearity, headroom, etc.) I've had solid state amplifiers that had error terms in the range of ppm, virtually a perfect voltage source and yet the sound quality (yes even in DBT) was demonstrably inferior to a much less well specified amplifier. To this day I have no answer to that question. So ultimately I measure and listen - which from experience is pretty standard audio industry practice. (I'm not going to say that small boutique vendors adhere to the tenets of scientific rigor, but you will find that at least some do.) My dogma is that I think you need to both measure and listen so can I have my own objectivist_subjectivist camp too??
www.kta-hifi.net Last edited by kevinkr; 10th November 2009 at 05:07 PM. |
#9 | |
Just as a side note, I was at University of Texas this morning visiting a neurobiology lab. They use Tektronix 502 scopes and laid in a large stock of replacement tubes. The prof (a top researcher, AAAS Fellow, and all that) maintained that he got better data for their sensitive measurements with the tubed scopes than any solid state ones he had tried which sold for less than $30k. No room for irrationalism in Big Science.
#10 |
The Tek 502 has an excellent front end on it, and delivers .1 mV/division very comfortably. It's the only one I've kept functional out of about 20 various models that I've acquired for parts. It has tube rectifiers for one( nice to think about the stash the proff has laid in to keep them running at 2x GZ34 each )...
cheers, Douglas
the Tnuctipun will return |
| search for ultimate system | mvagusta | Multi-Way | 25 | 10th September 2004 05:04 AM |
| Page generated in 0.14989 seconds (80.20% PHP - 19.80% MySQL) with 11 queries |
