| diyAudio Sponsor | ||
#2 |
...schematic link?... or attach?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
#4 |
from your main earth point take a (black)wire for "c+a"
and then an other (black)wire from your main earth point going to "f "first through to "a" and then a bit of (white)wire from the "0 ohm tap on the out-put transformer" to point "a" use about 1mm core wire (or may be a bit less) try to make the white wire one strand of copper core wire |
#5 |
Thanks Pointy for how to connect all groundings.
I need a help of understanding the logics of all groundings from a through f. |
#6 |
dontellpapa: Search this forum for "star grounding"
As a general rule of thumb (for star grounding), to reduce hum, you want to tie all of the signal grounds to one common point, which may also be your safety ground, or use one connection to tie the star ground point to the chassis/safety ground if they are not the same point. Another grounding scheme is buss grounding. The objective with either scheme is to reduce/eliminate ground loops due to differing voltage potential at the grounding points. Poindexter has a mini-dissertation on grounding and hum here (about 1/2 way down the page): THE MUSICAL MACHINE; IMPLEMENTATION. |
#7 |
that was from f to a ........ anyway from your "main earth" to "f"
then from "f" to "e" then "e" lastly to "a" and don't forget to bring the white wire from "0 ohms tap of the out-put transformer" to "a" also this is an old style of earthing and it's true you may find "star earthing" better |
#8 |
Thanks for all your feedback above.
However, I wanted to understand the reason of the grounding in each location of the diagram above. At least I like to know when/where to place grounding from the diagram. Thanks. Dontellpapa |
#9 |
Just a quick non grounding related note on your schematic - the LED that you have shown on the primary side will die of excessive reverse voltage (max spec is around 4-5V). You need to put a diode in parallel with it with reverse polarity to prevent this.
#10 |
put the diode in series with the LED. That will drop the power dissipated in the resistor by half.
regards Andrew T. |
| questions about grounding and noise | zhai | Analog Line Level | 0 | 17th October 2007 11:50 AM |
| Grounding questions | arjscott | Solid State | 6 | 20th March 2007 04:23 PM |
| Star Grounding Questions | LHMAudio | Solid State | 5 | 12th May 2006 04:31 PM |
| grounding & power supply questions | timsch75 | Chip Amps | 2 | 15th January 2004 05:04 PM |
| Questions re: digital grounding | echo | Digital Source | 33 | 14th October 2002 06:31 PM |
| Page generated in 0.11367 seconds (69.36% PHP - 30.64% MySQL) with 11 queries |
