| diyAudio Sponsor | ||
I wish to build a stereo vacuum tube amp using 6V6 output tubes. The schematic calls for a transformer at 700 volts center tapped. I have an 800 volt CT transformer. Can I use this transformer with some modification?
#2 | |
You should be able to do just fine for 6V6 "finals", with the 400-0-400 power trafo you already have. If you SS rectify and choke I/P filter the B+, the rail voltage will come at about 360 V. That rates to be fine for self biased 6V6s.
Eli D. |
#3 |
[URL="http://webpages.charter.net/dawill/tmoranwms/Elec_Frankenhouse.html"]
This is a link to the schematic. |
#5 |
Hmmm....
I don't think "a cool red glow on the 6V6 plates" is such a good idea. Seems I read somewhere that this indicated one was exceeding the recommended plate dissipation and would lead to shortened tube life. But, I probably read it on the internet so ignore me..... |
#6 |
The OP's reference schematic is here.
That's a mono amp. The remark about red plates being bad is CORRECT. The 6V6 should be biased at about 23 V. and power O/P is about 15 W. The circuit shown follows the Scott/Dyna pattern of pentode voltage amplifier and "concertina" phase splitter. Notice the "Cheap Charlie" bias supply. Bob, per my 1st post, you can use the power trafo you have. Switching from "fixed" to self bias is in order. Is a stereoblock build part of the plan?
Eli D. |
#7 |
PSUDII is your friend - model it...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#8 |
Yes, I would like to build a stereo version.
Bob |
#9 |
Use a 5R4 or something that loves to burn volts...
#10 |
What is the power capability of the PTX you have? Voltage is fine, but if you haven't got current, you haven't got squat...
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| is there a circuit for a power supply to power the differant add on clocks | frank2395 | Digital Source | 1 | 30th June 2005 09:33 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.09255 seconds (81.54% PHP - 18.46% MySQL) with 10 queries |
