diyAudio Sponsor
Old 10th November 2009, 01:52 AM   #1
Fenris is offline Fenris  United States
Default Strange idea for an output stage - comments requested
So I had an idea the other day while looking at parafeed designs and reading the thread on using power toroids as OPTs. I've got a pretty big junk box an have been looking for a project to clear alot out of it. Starting with a standard Williamson style front end - plate follower with split load phase splitter, nothing exciting here. Then a 6L6GC in parafeed with a CCS. I figured I'd add a second output tube in paralell, but a dual primary power toroid would give me a little more flexibility in wiring. I was thinking that running the tubes and transformer windings in opposite phases from each other would help with overall linearity. Has anyone tried something like this or see any pitfalls? I'm thinking it still has overall low power output compared to a P-P amp. If there's a major problem, I'd just go with a more standard P-P arrangement, but I figure I'd ask the experts first. Thanks.
PS. - B+ of around 360v.
Listen to the music through the stereo, not the stereo through the music.
Old 10th November 2009, 02:04 AM   #2
Iain McNeill's Avatar
I'm a sand-guy so forgive me if I'm missing something here. If the primary windings were ground referenced rather than cathode referenced wouldn't this be equivalent to a PP output, assuming zero PSU impedance?
Old 10th November 2009, 03:08 AM   #3
smoking-amp's Avatar
It will sound like P-P. Some possible advantage as far as PSRR, since the primaries are ground referenced instead of B+ reference. And the xfmr will be DC balanced. But those CCS's on the outputs are going to burn up power. And the output tubes have to run in class A too. I think this may be close to summing the disadvantages of SE parafeed with the disadvantages of P-P.
I think the caps to the primaries could be dispensed with if the primaries are just series connected between the plates. And the CCS's could be dispensed with by using a separate center tapped inductor to B+. But then it loses the PSRR advantage. Although P-P largely cancels out the Power Supply effects to first order anyway.
Ohms Law V = I R
Old 10th November 2009, 03:29 AM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Para-Feed push pull. Should work.
Try it and tell us how it sounds.
Old 10th November 2009, 03:46 AM   #5
ChrisA is offline ChrisA  United States
You are using a power transformer for output? I doubt there is any interweave in the coils. What is their spec for leakage inductance? Power transformers are not designed to work past 60Hz.
Old 10th November 2009, 06:12 AM   #6
analog_sa's Avatar
Toroids work just fine. That's why they shouldn't be used in power supplies.
Old 10th November 2009, 06:21 AM   #7
rdf is offline rdf  Canada
rdf's Avatar
An easier option might be to put the CCSs on the cathodes bypassed with a cap. They make it trivial to null static DC in the toroid primary.
Edit: CCSs in the plate circuit means losing half the B+ to permit Vp swing.
Ears aren't microphones.
Old 10th November 2009, 06:25 AM   #8
frugal-phile(tm)
planet10's Avatar
Old 10th November 2009, 06:34 AM   #9
Geek's Avatar
You are using a power transformer for output? ..... Power transformers are not designed to work past 60Hz.
They rock in guitar amps though
Cheers!
Old 10th November 2009, 11:46 AM   #10
http://www.anc-tv.ne.jp/~suzuki3/amp...300Bpp_Amp.pdf
This schematic will be of your interest. You can find it on a Japanese DIYer's website. As the website says in Japanese (sorry), the original design of this SE-PP switchable class-A 300b amp was actually published by Mr. Takaaki Uzike (or Ujike) in a couple of issues of RADIO GIJYUTSU magazine (a monthly Japanese DIY magazine like MJ) in 2000. In the articles, he says he developed the circuit and assembled his 300b amp, in order to make the best use of Permalloy PP output transformers, and named this output stage configuration "floating OPT", which I think is equivalent to "parafeed PP". Mr. Uzike used a pair of Tango NY-45-5 (discontinued).
Yoshi
Wacky TL idea, comments? sifka4 Subwoofers 5 25th November 2008 01:43 AM
Strange preamplifier output stage Groundloops Solid State 5 21st December 2007 01:54 AM
Interesting output stage idea keantoken Solid State 18 15th November 2006 11:41 PM
Strange damping idea ... ? eppo Full Range 0 23rd May 2006 09:57 PM
Strange idea? Daniel-A Multi-Way 6 27th October 2004 08:25 PM
Page generated in 0.16128 seconds (60.21% PHP - 39.79% MySQL) with 11 queries
