| diyAudio Sponsor | ||
I am a newbie ... don't laugh ya !
OK ... wish to build a #26 linestage but having problem getting the 1.5VDC required for the #26 tube! Built Chris Brady's design : 5VAC~Schottky bridge~10K uf~0.47R~10K uf~LM1086~1.2R . I got 4.7VDC !? From here, how do I acheives the 1.5VDC@1A needed for the Type 26 tube? Thanks for looking & any help forecoming, Zekk |
#2 | |
Don't know about this design, but you mention the 1.2R resistor, and therefore I think the LM1086 is configured as a CCS (the 1.2R between adjust and output, and the tube filament fed from 'adj'). This means that the regulator will pass only 1A, which multiplied by the Resistance of the 26's cathode will develop 1,5V. Prior to testing that, just post the schematic! Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY! |
#3 |
In principle that should work, with LM1086 as current source. that means 1.2R between adj and out pins. Be careful to take the output from the adjust pin!! This may be where you are going wrong.
To make sure you have enough headroom, just try taking the capacitor straight to the LM1086 input. you need about 4.5v going into the LM1086. I use a 6v secondary. But I suspect you've wired the LM1086 wrong, as above. andy |
#4 |
And don't forget to measure the output voltage with a tube or equivalent resistor connected at output.
#5 | |
LM1086 is a low-dropout regulator so it only needs ~1.5V voltage above the desired output, which would explain your high voltage measurement (4.7V) with open terminals. By the way, make sure your LM1086 has some sort of cooling (= a suitable heatsink) as it is going to dissipate approximately 5 watts during operation. |
#6 |
First and foremost, many thanks to all the kind soul out there who've given me the help to build this unique linestage.
Loaded with a 1.5R resistor as adviced and there it is, a 1.5VDC reading! Cheers! Zekk |
| dc heater supply help | milen007 | Tubes / Valves | 17 | 21st February 2009 07:42 AM |
| Lessons learned building a 5VDC Power Supply for a 300B heater | sgerus | Tubes / Valves | 14 | 18th July 2008 06:17 PM |
| DC PSU for both 6.3vdc and 5vdc from one 6.3vac transformer? | sgerus | Tubes / Valves | 0 | 29th February 2008 04:47 PM |
| help with heater supply | jarthel | Tubes / Valves | 5 | 24th July 2003 01:12 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.08864 seconds (78.41% PHP - 21.59% MySQL) with 10 queries |
