diyAudio Sponsor
Old 8th November 2009, 06:05 PM   #1
Default original philips AD-9058
i have two ultra-linear push pull output transformers philips model AD-9058.i know that it fits with ECL 86 tubes.Can i use EL84 tubes for these transformer i do not have more specifications for these.
Old 8th November 2009, 08:20 PM   #2
pointy is offline pointy  United Kingdom
pointy's Avatar
http://www.gloeidraad.nl/radioforum/...3DpZu%26sa%3DG
http://www.r-type.org/pdfs/el84.pdf
you may need to copy and paste the top link to get it to work
but the match does not look that good 1 watt out at best and 1k ohm difference a~a
if you were to keep the WATTS DOWN you may get ok sound out
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
Original Philips cdplayer service documentation VanHal Swap Meet 2 10th February 2010 09:03 AM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
For Sale 3 pieces NOS Philips TDA1541A S1 Very Rare! Original! bezobraznia Swap Meet 15 4th March 2006 07:01 AM
Page generated in 0.05975 seconds (71.14% PHP - 28.86% MySQL) with 10 queries
