| diyAudio Sponsor | ||
Hello,
I had my TubeLab SE (with JJ 300Bs) running for more than 3 months now but recently I noticed that after 2-3 minutes of playing music the 300Bs will turn off while tyhe rectifier and the input tubes are still on. Never had this problem before. The 300Bs are biased at 75ma. The input tubes are at 170 volts. B+ at 340 volts. Can someone shed me some light on what is going on here? How can I narrow the origin of this problem? Thanks for your help. Doc Jr 8156 |
#2 |
Isn't that the power drive overheating issue? Got a big enough heat sink?
#3 |
#5 |
Thanks Bill and Sendy. Bill, the heatsink in there now had been there for 3 months and never had this problem before but I will investigate that. Sendy, maybe defect in the tube sockets? The input tubes and the rectifier remained lit when the 300B shuts off. The tubes were fine when tested on my other 300B amp though. Will it help if I'll install independent heater transformers? Thanks again.
Doc Jr 8156 |
#6 |
If you have another 300B, can you exchange and test amplifier with other piece 300B ?
#7 |
Doc,
If by "300B shutting off" you mean that the filaments turn off, read on. There are many possible reasons for why you didn't see the issue earlier but is seeing it now. Maybe the heat sink has more dust on it now. Maybe the 300B filaments have aged and draw slightly more current. It is also possible that the AC line voltage has changed slightly, so now the Sharp regulator has a larger voltage across it and dissipates more power. It sounds like it's a marginal heat sink design to begin with. Put a bigger heat sink on it. Use thermal grease between the regulator package and the heat sink - or at least a thermally conductive silicone washer. The stuff is available at DigiKey Corp. | Electronic Components Distributor | United States Home Page and elsewhere. A new heater transformer will not solve the problem. A new heater transformer will not change the power dissipated in the regulator. ~Tom |
#8 |
Hello Sendy and tomchr,
Thanks for responding. Sendy, I will try other 300Bs n there. Tomchr, the heatsink in there is only 1X1/2 inch square. I'll get a bigger one. On the original sink, I used both silicone wafer and thermal grease. What if i'll change the regulator to a 7 amp one instead of the 5 amp in there? Godspeed. Doc Jr 8156 |
#9 |
Try Arctic Silver used for computer CPU's etc. Works better than white grease. A computer CPU heatsink with fan may be worth a try. They can be found for free from discarded computers. Larger ones recommended. When cleaning fan and heatsink with compressed air or vacuum cleaner, hold fan so it doesn't spin as dirt seems to get in bearings easier when spinning.
Good luck, Randy |
#10 |
I forgot to say you will need power to run fan. DC tube heater might have enough voltage. 5V might be enough and it will be quieter too. I believe fans run on 12V.
Randy |
| diy tube amp problem | ectobia | Tubes / Valves | 4 | 14th June 2006 08:50 PM |
| Tube defect - What is the problem. | gary f | Tubes / Valves | 2 | 7th November 2004 06:17 PM |
| Tube preamp problem | @mot | Tubes / Valves | 20 | 23rd September 2004 07:50 PM |
| Page generated in 0.10462 seconds (74.89% PHP - 25.11% MySQL) with 11 queries |
