| diyAudio Sponsor | ||
Hello,
I have a question for the knowledgeable tube socket people out there! I found a few cheap sockets that look like they will do the job, but which one is best? I need to replace a tube socket in a Fender Vibro Champ guitar amplifier. The original tube socket over heated in a spot and the insulation is now conductive creating a resistive short from the output pin to the heater pin on a 6V6 tube. I scraped a groove out of the burnt part until I got into a good portion of the socket insulation, & could not read any resistance with my ohm-meter afterwards, & the amp works fine, but I want to replace the tube socket since it was heated to that extent & I believe it is no longer reliable. I am thinking a previous output tube shorted and caused it to overheat & that’s what led to the problem, as everything else in the amp seems fine & sounds good after I separated the short circuit. (the amp was missing the rectifier tube & output tube when brought to me so I can't test any tube for shorts). Here are the sockets I found on ebay that I will probably be buying, but I would like to know which one is a better quality or are they about the same (the price is the same). I know one is ceramic, but I am unsure of the other, & one says Micalex. Can someone tell me which is better for my application? Seems like the ceramic would be a good choice, but I really don’t know. I don’t work on much tube equipment (still learning as I get the stuff brought to me for repair) so my knowledge is limited on tube sockets, the ceramic ones look good, but the black ones look almost the same as the original ones, the brown ones look really close too. I think the ceramic (white) ones would withstand more heat, but I don’t know for sure, if the ceramic is better I will use them. Both the output tube (6V6) & rectifier tube (5Y3) use the same socket, I think I may change them both so they match, but the rectifier socket still looks great. Here are the ebay item numbers to the sockets I am looking at getting (I could not seem to get the links to work, so if you can, the item numbers can be copy & pasted into the ebay search): Here is the white ceramic socket: 8 pin ceramic octal tube socket bottom mnt 6L6 6V6 EL34 Item number: 150383787642 or Here is the black one that looks very similar to the original brown socket in the amp (I don’t know the material of this one, maybe bakelite or something): 8 pin octal tube socket 1 1/16" top mount 6SN7 6V6 EL34 Item number: 150383787634 or I seen this one as well, it says its made out of Micalex (not sure what that is or if it’s a good insulator) although it may be a tight fit, but I already figured I may have to make the chassis hole slightly larger to accommodate the new sockets anyway, so I guess that’s not a big issue: 8 pin Micalex octal tube socket for 6V6 6L6 EL34 6SN7 Item number: 150383787638 There all the same price so whichever is best for my application I will get. I hope someone with knowledge on this can help! I do appreciate it! Thank you all & I hope to get some info on this. Take care! Pioneer621 |
#2 |
Honestly, any of those will likely outlive you. We're not takling 6146B's in a VHF transmitter... just a 6V6 class guitar amp ![]() Cheers! |
#3 |
I've used the Belton sockets, which are made of Micalex. They're not too expensive and I've been extremely happy with how nice they are. They seem better than the slightly less expensive generic ceramic sockets.
#4 |
One thing to remember is to be careful when you're soldering on any of those sockets. I had to steal a contact from a spare socket to fix a place where the solder got into the pin contact in one position, preventing the tube from being inserted (too much solder/cooking the connection too long). It was easy to fix, but I hated having to rob Peter to pay Paul, as it were. Now I have a spare Belton 9-pin that's good for nothing but supplying contacts to fix future screw-ups.
#5 | |
I discovered this Aoyue 936 soldering station for less than $45 shipped. It's so much nicer to use, and was well worth the price. It is a real temperature controlled station, so it is much easier to avoid cooking the thing you are trying to solder. ![]() http://s69.photobucket.com/albums/i4...o/aoyue936.jpg Last edited by Ty_Bower; 7th November 2009 at 01:01 PM. |
#6 | |
I try to use the old style white creamic sockets in guitar amps since they are immune to being carbonized (burnt, what happened to your socket).
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#7 |
Aspects of the exchange of slots:
1. mechanical compatibility 2. quality insulating and temperature resistance - for power tubes is very good ceramics, glazed ceramics better 3. quality and lifetime of contacts, must be flexible and not brittle, the shape of contact, material, plating, etc.. |
#8 |
Ty, I'm using a Weller WTPC temperature controlled iron. The problem was too much solder applied to the lug, and it wicked down into the socket contact. Working on the chassis all the time with it tilted on its side and all the lugs in the horizontal plane would have helped prevent the mishap. Anyway, it's fixed, and the amp is working. More about that in the "Kingfisher" thread.
#9 |
In my opinion the worst oct sockets in the business; top mounted chinese octal with flange. NoWay can 6550 /6L6 types stand straight inthese sockets unsupported without a champagne or jock strap.
#10 | ||||||
Thanks for the responses everyone!
I was thinking the ceramic socket would work ok in this amp, so I am leaning towards that one, but still not sure yet. If it will help prevent this problem in the future, it might not hurt going with ceramic. Quote:
I think the ceramic one would be a good choice & I think I may go with that. As for quality I am not sure with the ones I am watching on ebay. They are low cost so I assume quality is not the greatest, but will it be good enough for the guitar amp I am putting them in? Quote:
I was going to order a couple today, was going to go with the ceramic as it seems they are a good choice for the power tubes & should not have any problems, but after reading richwalters post it got me wondering if they are going to hold the tubes in place without any trouble, I would hate to find out the tube slipped out of the socket, the tubes seem to fit nice and snug in the factory sockets, hopefully these sockets on ebay will hold them in equally well? I think I am going to go with the ceramic ones on ebay (Item number: 150383787642); they seem cheap enough to try out. Anybody have experience with these particular sockets? Hopefully they will work ok, I think they will. I thank you all for the information & it definitely helps! I guess it kind of comes down to quality & hopefully the ceramic one will be good enough. I think I will wait until later today to buy them so I can maybe get some more info, but if not, the price is pretty low so I may just grab two & see what I think after they get here. Again, I thank you all very much! |
| Tube socket for ECC88, drawing | peranders | Tubes / Valves | 7 | 10th August 2009 02:59 PM |
| tube socket sale | tubesocket | Vendor's Bazaar | 21 | 11th November 2008 01:36 AM |
| Best Socket Material? | Jay | Tubes / Valves | 55 | 20th July 2007 11:20 PM |
| Help on tube socket | dung0981 | Tubes / Valves | 6 | 5th August 2006 09:31 AM |
| Tube socket wanted. (help where) | Hojvaelde | Tubes / Valves | 3 | 22nd June 2005 12:29 AM |
| Page generated in 0.17637 seconds (85.40% PHP - 14.60% MySQL) with 11 queries |
