| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Greetings everyone,
Does anyone have specs for the 6DQ5 in P-P audio service? Load resistance, bias, plate & screen voltage? I've searched the Internet and haven't found anything. Thanks, Ray |
#2 |
hey-Hey!!!,
You're going to have to do some load line drawing. For pentode mode. pick your g2 voltage and B+ and see what fits in under the dissipation line. For triode mode, it is just a matter of picking a load 3-4x the plate resistance and an OP under the limits. cheers, Douglas
the Tnuctipun will return |
#3 |
6DQ5 is very close with 7867 and less close with 6EX6, 6CB5A and 6CD6GA, but can work in any amplifier with any of those tubes (small bias correction).
Also seem very useful in G2-drive amplifier. |
#4 |
Interesting - the specs of the 6BQ5 and 7867 do look pretty close. I had my eye on the 6BQ5 for screen driven duty, but I may try it elsewhere. On a similar note, one of our members has coaxed decent push-pull performance out of the 6BQ6, an unabashed sweep tube. Georce (Tubelab) has also thrahsed some amazing amounts of power out of a pair of 6BQ6 as well, though that was a "test to extinction" situation.
#5 |
6DQ5 is a big brother of 6BQ6, about 2-3 times bigger and stronger! But yes, the same principle can use to drive 6DQ5, 7867 and other big similar tubes. 4 tubes 6DQ5 can give 200W in normal Push-Pull class AB1 with less than 4% distortion, and same output tubes work last 3 years every day 4-5 hours. (drive at g1: Ua=600V, Ug2=150Vstab.,Ug1=-45V, Ra-a=3800ohms, Ia-min=2x30mA, Ug1eff.~2x40Veff.)
#6 | |
GlassFET
![]() Cheers!
-= Gregg =- "Ratings are for transistors...tubes have guidelines" Hobby and communites - GeeK ZonE Commercial site - classicvalve.ca diyAudio Blog - GeeK's Bench |
#7 |
Here is some interesting info:
I was hanging out at Stans (ESRC) swap tables during a rain shower at the Dayton hamfest. I spent that time looking at tubes. If I spot a big box with a number that I don't know, or vaguely remember from my past, I will open the box and check out the tube. I have "discovered" a few winners that way. I remember the 6DQ5 from the dawn of the color TV era as being a big sweep tube that was never very popular. I found several in Stans collection, looked at them, and then put them back when I found that they were $10 each. I prefer cheap tubes for obvious reasons. Maybe 5 minutes later a guy walked up and asked for 6DQ5's. He said that he was using them in an OTL audio amplifier. He wanted a particular RCA to match the ones that he already had. I added that number to my shopping list and managed to find a few used $1 6DQ5's that didn't look too bad. I have collected about 6 since then. Investigating the specs reveals a very high peak cathode current rating for a 1950's vintage tube, 1 AMP. This is why they work in OTL's and they will probably make a good P-P output tube. I'll hook mine up eventually.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#8 |
I did not try this schematic.
#9 |
GlassFET
I'd try that.... but with a less wimpy 250V reg screen and 400-500V anode
![]() I've used this tube in some kick butt power supplies before I got my Lambda ... pretty unperturbable tube ![]() Cheers!
| Thread Tools | |
| Need specs for Toshiba, Planet Audio | SharpyWarpy | Multi-Way | 0 | 21st April 2007 07:00 AM |
| Audio transformer specs | fatmarley | Parts | 6 | 21st January 2007 03:42 PM |
| Need Specs On Peerless S-217d Audio Transformer | ARHAICAUDIO | Parts | 0 | 13th April 2006 03:37 AM |
| Audio Note Trans 205 specs? | dshortt9 | Tubes / Valves | 0 | 15th June 2005 06:23 AM |
| ATSC unveils new digital audio specs | Da5id4Vz | Everything Else | 0 | 9th April 2004 03:22 PM |
| Page generated in 0.51992297 seconds (64.89% PHP - 35.11% MySQL) with 11 queries |
