diyAudio Sponsor
Old 31st December 2010, 05:00 PM   #11
davorin is offline davorin  Croatia
Here You are the best I have:
Old 31st December 2010, 05:12 PM   #12
Sorry, this is the best:
Old 31st December 2010, 08:14 PM   #13
wrenchone's Avatar
This look like a job for the One Electron UBT-1...
Old 1st January 2011, 12:49 PM   #14
hey-Hey!!!,
And now for a Class A option: B+ of 250, g2 of 100V and a-a load of 5k. Idle at ~90 mA per tube. I am building right now with 6CB5A; B+ around 270V, g2 reg'd around 110V( adjustable in LMA329 steps ) with a 5k a-a load. Obviously not going for Max Power... Front end is an E-Linear LTP using EL84's( pentode-mode ). I'll post a schematic as soon as I can scan it.
cheers,
Douglas
the Tnuctipun will return
Old 19th October 2011, 07:31 PM   #15
Did you ever try this? I have one of these (6dq5) in the original box, would like to try it in a single-ended triode kind of circuit. Not much info out there.
Need specs for Toshiba, Planet Audio SharpyWarpy Multi-Way 0 21st April 2007 06:00 AM
Audio transformer specs fatmarley Parts 6 21st January 2007 02:42 PM
Need Specs On Peerless S-217d Audio Transformer ARHAICAUDIO Parts 0 13th April 2006 02:37 AM
Audio Note Trans 205 specs? dshortt9 Tubes / Valves 0 15th June 2005 05:23 AM
ATSC unveils new digital audio specs Da5id4Vz Everything Else 0 9th April 2004 02:22 PM
Page generated in 0.09188 seconds (62.12% PHP - 37.88% MySQL) with 11 queries
