diyAudio Sponsor
Old 5th November 2009, 02:09 AM   #1
aardvarkash10's Avatar
Default Help reqd - 115V PTX on 230V
OK, here's the thing. I bought three jukebox amps a little while ago. They are all ex-USA and have nice PTX in them, but wound for 115VAC primary.
We are 230VAC here in NZ.
After mulling it all over, I thought about doing this - half wave rectify the primary. Result (theoretically) is the same secondary voltages but potentially lumpy ripple.
Anyone see any issues?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 5th November 2009, 02:35 AM   #2
Send a message via AIM to DigitalJunkie
No,No.. You'll end up with DC half-cycles on the primary,which will make it very unhappy.It will saturate,and buzz and growl,before it starts releasing magic smoke.
Old 5th November 2009, 02:38 AM   #3
you sure? How so?
Old 5th November 2009, 02:41 AM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Transformers don't like to be saturated. Dc Saturates transformers. Rectified AC is the equivalent of DC. Poof!
Old 5th November 2009, 02:43 AM   #5
TheGimp's Avatar
1) Get a 220:115 Auto or Isolation transformer and step the voltage down for the amp.
2) Buy a new transformer with the proper input and output and replace the transformer.
Or best yet.....
Send it to me and I'll run it on 115VAC... ;^}
Old 5th November 2009, 02:44 AM   #6
The primary current is rising and falling - not DC as much as half wave AC. The only true DC component is when the diode is reverse biased, and then its no current at all surely... HTF can it saturate?
Old 5th November 2009, 02:51 AM   #7
TheGimp's Avatar
The average is DC. That is what counts.
Old 5th November 2009, 02:53 AM   #8
nice try gimp! Tell you what, you come and get them. Bring some suitable toroidals (dual 115 primary) to replace them since you guys can get them cheap!
Old 5th November 2009, 02:54 AM   #9
ok - I'm going to try it on a small PTX and see what happens... George-like reports back at you on completion!
edit - heres what I expect to see...
Last edited by aardvarkash10; 5th November 2009 at 03:12 AM. Reason: altered attached image
Old 5th November 2009, 03:50 AM   #10
I guess it may not release the magic smoke,but I think the transformer will buzz and run a bit hot,it won't be too happy.
It's a similar situation to mains with DC on it (a common problem with toroids in particular),and you'll actually be contributing to the DC on the mains..which may make other equipment unhappy.
JBL eon15 g2 schematics reqd jayam000 Solid State 1 2nd May 2009 06:04 PM
Help Convert Bryston BP-20 PS from 230v to 115v ainami Solid State 5 12th December 2008 06:01 AM
Question about autotransformer ( 230V to 115V ) Rodeodave Power Supplies 5 4th June 2007 01:11 PM
115v conversion fro 230V Cambridge Audio CD4 and Dacmagic 2i taskerc Digital Source 4 7th February 2006 07:02 PM
Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers Eva Swap Meet 1 28th July 2005 03:00 PM
Page generated in 0.10709 seconds (69.68% PHP - 30.32% MySQL) with 11 queries
