diyAudio Sponsor
Old 5th November 2009, 03:45 PM   #11
OneyedK is offline OneyedK  Belgium
(1) sorry, but I don't see how this is relevant? No matter how you decide to bias, you still have to couple with previous stages.
(2) Negative power supply can be rather simple, since the current needed is almost nothing, unless you're talking about using an interstage transformer, wich brings us back to (1).
(3) Without the transformer (again) the LPF formed by Rg1 and the miller capacitance of the tube will get rid of most noise, not that I want to say that we have to design a negative power supply without care!
But hey, just my 2 cents, maybe I'm looking at it the wrong way
Enlighten me please...
Old 5th November 2009, 05:41 PM   #12
kevinkr's Avatar
In most applications the bias supply is completely divorced from the grid circuit by the grid resistor. As the previous poster pointed out most tube amplifier circuits are RC coupled. In the case of an IT application it is a bit more complex, but honestly speaking I have never found large value cathode bypass caps no matter who makes them to be particularly transparent.
I use fixed bias in just about every power stage I have ever designed, and find the inconvenience of an additional supply inconsequential.
Battery bias in some cases is convenient, in other cases one can use LEDs in the cathode circuit for what is effectively fixed bias operation. (See SY's red light district, etc. for examples.)
www.kta-hifi.net
Old 6th November 2009, 02:31 AM   #13
rdf is offline rdf  Canada
rdf's Avatar
Possibly a better option is to current source the LEDs and put them in the grid circuit in series with the grid resistor. Since the dynamic signal current through them is infinitesimally smaller, so is any impact from non-linearity.
Blame the Manichaeists
Replacing a cathode resistor with a CCS Original Burnedfingers Tubes / Valves 87 15th June 2008 02:04 AM
TVA-1 cathode resistor value audiohead Tubes / Valves 3 9th December 2007 08:15 PM
Replacing a 12AU7 in a cathode-follower. beppe61 Tubes / Valves 51 28th March 2007 09:05 AM
Schematic please? SRPP with current source cathode follower riotubes Tubes / Valves 0 7th January 2007 06:18 PM
Active current source or power resistor? woody Everything Else 2 19th September 2002 04:33 AM
Page generated in 0.06417 seconds (83.46% PHP - 16.54% MySQL) with 10 queries
